Mimic(мнемосхема)
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Mimic(мнемосхема)
Viewing 8 posts - 31 through 38 (of 38 total)
  • #748
    Evgen
    Hello!
    I have a question again . How do the following , there is a current sensor (for example) and you want to within a second track it on, off and currents that go beyond the upper and lower limits ? And what would the data in the events to be displayed for example.
    #755
    You can set bounds for an input channel using SCADA-Administrator. When the channel value is above or below defined limits, event is generated.
    If you need events when device turned ON or OFF, you should create additional channels of the type Calculated discrete and tick Write events and Events on change checkboxes for these channels.
    #757
    Evgen
    Hello!
    I have a question again. If you load long cargo and mimic podvisat is how to solve this trouble?
    #758
    Please provide more details of your issue.
    #759
    Evgen
    When you open the page Rapid SCADA mimic long time to boot, sometimes up to a minute.
    there is a way to speed up the loading
    a problem with your computer or network is excluded, local enterprise sites loaded quickly
    #760
    Could you send me by email a file of your scheme to test?
    #761
    Evgen
    Give your email I will send
    #762
    Evgen
    https://yadi.sk/i/hUuFKJH8knDRW
    Here screen problems
