Evento de perda de comunicação – Rapid SCADA 6.2.2
Forum Home › Forums › Communicating with Devices › Modbus › Evento de perda de comunicação – Rapid SCADA 6.2.2
Viewing 9 posts - 31 through 39 (of 39 total)
  • #17714
    ExportTON
    try to import
    #17717
    “Error saving the Scripts table” is so weird. How to reproduce it?
    #17718
    It’s possible to use Auto Control Module to react on channel change with a delay. Perhaps, it is easier to configure the module via UI, because formulas are not needed in that case.
    #17724
    isabellacog
    When I created the script, my server stopped working. The errors that appear are the ones shown in the image.
    https://imgur.com/XqFxH9t script
    https://imgur.com/ohZxCGY error
    I tested both the TON script and also a very simple formula using Val(), and the same problem occurred.
    I am able to save the script in Administrator, but when I deploy the configuration, the server stops running and those errors appear. I didn’t even create a channel using the script yet — the problem happens just by having the script in the Scripts table.
    If I delete the script and deploy again, the server starts running normally.
    So it seems that any script added to the Scripts table causes the server to stop after deployment, even a very simple one.
    Do you know what could cause this behavior?
    Also, regarding the Auto Control Module solution: how would that work in this case?
    Do I need to install or download this module, or is it included by default?
    I would still like to understand and fix the script approach, because I want to learn why it is not working in my project.
    Thank you!
    • This reply was modified 7 months, 3 weeks ago by Mikhail.
    #17728
    Definitely, in the script should not be any XML tags.
    It is a good practice to check ScadaServer.log after uploading the project if scripts were changed.
    #17729
    An XML script is the result of an export from a script table. It needs to be imported, not copied as it is. XML is saved in UTF-8 format, so there should be no errors due to the operation of the site, etc.
    #17757
    isabellacog
    I managed to get it working by importing the script — thanks for the guidance!
    Now I have a question about the Beep functionality. I configured the channel events by enabling: 0: Event enabled, 1: Event beep, and 3: Channel data has changed. However, the beep only sounds once.
    Is there a way to make it beep repeatedly until an operator acknowledges the alarm? Something like a continuous or repeating beep until acknowledgment would be ideal for our use case.
    Has anyone implemented something like this?
    #17761
    If you have a Windows system and the Server is both an operator’s computer, then you can use the sound module.
    ModAlarmFork
    If Linux or everything is separate, the web client connects remotely. The option is to use the Auto Control Module and somehow play with scripts. Another option is to add your own html page with sound to the i-frame on each page and show it when there are events, and then use a script to repeat it. In general, I have not tried these options in any way. Maybe the developer will tell you something.
    #17762
    Please create a new topic for the different question.
  • The topic ‘Evento de perda de comunicação – Rapid SCADA 6.2.2’ is closed to new replies.
