Convert decimal to hexadecimal from web browser
Forum Home › Forums › Understanding the Software › Convert decimal to hexadecimal from web browser
Viewing 12 posts - 31 through 42 (of 42 total)
  • #13144
    public byte[] NewFreq1()
    string tes = Encoding.UTF8.GetString(CmdData);
    uint teu = uint.Parse(tes)*100;
    byte[] teb = BitConverter.GetBytes(teu);
    return new byte[] { 0x00, 0x01, teb[1], teb[0]};
    We use the Binary command type and enter 30 and so on in string mode (not Hex)
    #13145
    kcks66
    Hi manjey73,
    Meantime, I tried to use automatic control module to perform quite similar task. My task is straight forward this round.
    I want an output channel send out value follow an input channel value; as example input channel 1001 has 15, I want the output channel 2001 to send out 15 also.
    I configured automatic control module as below but failed to get the result as I expected.
    https://ibb.co/hDs0jLN
    Pls advice and thank you.
    #13147
    Trigger parameters check Value. Edit Value = 15
    Command Value = 15
    #13148
    kcks66
    Hi manjey73,
    Ah, I think I didn’t ask the question properly. I wish the output channel send out value always follow input channel as the input channel value is always changed from 1 to 100.
    #13149
    Then you probably need a trigger to change the channel and specify “Send command” in the command.
    And if necessary, use the formula in the command to check the value for the range 0-100 and, if it goes beyond the range, return Double.NaN to cancel the command
    #13151
    kcks66
    Hi manjey73,
    Yes. I managed to copy the input channel to the output channel by using data change trigger.
    Now can I store a hexadecimal number in an input channel? I want to copy the hexadecimal number in an input channel to an output channel?
    #13152
    On the 5th version, there is no channel display as a HEX number, as in the 6th version. Most likely only using ASCII String with the corresponding transformations using formulas.
    #13153
    Tip: upgrade to version 6, it is somewhat more flexible
    #13154
    kcks66
    Hi manjey73,
    Currently I am waiting for an publish of instruction steps on how to migrate from V5 to V6. I will definitely want to use V6.
    #13155
    It seems there were publications on the Russian forum. As far as I understand, there is a difficulty only in transferring the database
    #13159
    Please read this topic. Instruction is inside the archive.
    #13163
    kcks66
    Hi Mikhail,
    Noted. Will give it a try.
