Web application output value Forum Home › Forums › Understanding the Software › Web application output value Tagged: output value This topic has 16 replies, 3 voices, and was last updated 9 years, 1 month ago by mjorge89. Viewing 2 posts - 16 through 17 (of 17 total) ← 1 2 Author Posts August 2, 2017 at 1:02 pm #2453 MikhailModerator Hi, SetVal(102, CmdVal) should work. But it may cause a error if your SCADA-Server is outdated. The actual version is 5.0.2.0. Please check. August 3, 2017 at 7:38 am #2456 mjorge89Participant Hi, Finally solved the issue. The problem was in the communicator config. I had the wrong byte order for the corresponding signal, so it walways read “0” in the channel. Tanks manjey73 and Mikhail for your help. Author Posts Viewing 2 posts - 16 through 17 (of 17 total) ← 1 2 You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
