Sending email by using Gmail sudden fail
Forum Home › Forums › Understanding the Software › Sending email by using Gmail sudden fail
Viewing 15 posts - 16 through 30 (of 40 total)
  • #12071
    hethongscada62
    Hello Victor,
    Please follow the all steps that Mr. Mikhail gave in instructions. Means to create an email mailbox in Yandex, then set up the properties of the email device as follows
    https://imgbb.su/image/xuFrpn
    And setup an Address book as instruction.
    Have a good result
    Han Hoang
    #12072
    hethongscada62
    Hi Victor,
    Noted that you have to Check the settings:
    https://ibb.co/hKd7VfT
    The best regards
    Han Hoang
    #12073
    hethongscada62
    Dear Mr. Mikhail,
    Sending email from directly from email device and via Auto control module have been tested on Windows. All they are working fine. But they are not work on RPi (Of course after installing Auto control plugin and configure a email driver) . So could you let me know: Which files (Auto control plugin and email driver) on Windows I have copy then past to RPi?
    Thanks and best regards
    Han Hoang
    #12075
    Do you use Rapid SCADA 5 or 6?
    #12076
    hethongscada62
    Dear Mr. Mikhail,
    I am using a Rapid Scada 5.
    Han Hoang
    #12077
    hethongscada62
    Dear Mr. Mikhail,
    And there are versions of drivers those are using in my project:
    KpEmail: version 5.0.1.1
    Kptelegram: version 5.0.2.0
    Communicator: version 5.2.1.0
    Server: version 5.1
    Thanks a lot
    Han Hoang
    #12078
    Copy the following files to RPi:
    /opt/scada/ScadaServer/Mod/ModAutoControl.dll
    /opt/scada/ScadaComm/KP/KpEmail.dll
    /opt/scada/ScadaComm/KP/KpTelegram.dll
    #12079
    hethongscada62
    Dear Mr. Mikhail,
    Thank you for your reply.
    I have done as you advised. There is strange, all both email and telegram drivers are working perfect on Windows but they can not work on RPi.
    https://imgbb.su/image/xTz7FM
    https://imgbb.su/image/xTzwyC
    Some thing is wrong on RPi, but where is it?
    Thanks a lot
    Han Hoang
    #12080
    hethongscada62
    Dear Mr. Mikhail,
    Thanks a lot
    Han Hoang
    #12085
    Looks like Mono version is too old.
    Current Mono version is 6.12.0, link.
    #12086
    To check Mono version, run the command
    mono --version
    #12101
    hethongscada62
    Dear Mr. Mikhail,
    The current Mono version is 6.12.0.122.
    https://imgbb.su/image/xq0tHS
    https://imgbb.su/image/xq0Vq6
    I think the current version is not too old but I am trying to update to Mono version 6.12.0.182 but I can not update.
    https://imgbb.su/image/xq0O16
    Has a another method to update?
    Thanks a lot
    Han Hoang
    #12104
    Mono 6.12.0.122 is up to date.
    But in the screenshot https://imgbb.su/image/xTz7FM the error is in Mono.Security.dll 4.0.0.0. Could you search for Mono.Security.dll inside subdirectories of /opt/scada ?
    If you found Mono.Security.dll there, delete it and restart the Rapid SCADA services.
    #12109
    hethongscada62
    Dear Mr. Mikhail,
    The mono.security.ddl was found and deleted. The KpEmail is working normal. The email is sending automatic perfectly, but KpTelegram has not executed.
    https://imgbb.su/image/xL80O1
    https://imgbb.su/image/xL8zNY
    https://imgbb.su/image/xL8xuW
    https://imgbb.su/image/xL8v0R
    Maybe there is not new Mono.Security.ddl in KP folder.
    I am finding online a new version of Mono.Security.ddl but i have not got a result.
    Do you have new Mono.Security.ddl file?
    Han Hoang
    #12114
    According to the provided line013.log, Telegram Driver requires a valid registration key.
