Register reading with Modbus TCP
Forum Home Forums Communicating with Devices Modbus Register reading with Modbus TCP
Viewing 8 posts - 16 through 23 (of 23 total)
  • #16710
    rapidscadaaks
    Yes. This matches with the documentation.
    #16720
    rapidscadaaks
    Hi
    Awaiting guidance for resolution.
    #16722
    Judging by the images from the Modpoll configuration documentation, everything seems to be the same, but your device simply does not respond to one of the commands.
    Perhaps the manufacturer changed something in the new version and did not update the documentation.
    If this command was supported, but you got the wrong address, the device would give an error response. Try polling one register from 0 using Holding Registers
    #16723
    rapidscadaaks
    Hi
    I tried polling one register from 0 using Holding Registers and there was no response from the unit
    I have created a support ticket with the manufacturer and await their response.
    In the meantime, please suggest software for testing purposes for sending command to the unit and getting response.
    #16724
    Well, use Modpoll as shown in the device documentation. If he answers, try to compare why he is not responding in scada.
    Also try to read just one element with the command 02
    Also check the InputRegisters reading.
    • This reply was modified 1 year, 1 month ago by manjey73.
    #16729
    I suppose, the manufacturer should somehow comment the situation. Please notify us about the result.
    #16752
    rapidscadaaks
    Hi
    Manufacturer (Waveshare) is not responding to the issue.
    I have checked connecting the device directly to the PC using serial port and values are not received for the Input Channels. The issue therefore is not Rapidscada related.
    I am therefore using alternate product and results are fine.
    Thank you for the assistance
    #16756
    Thank you for the update.
