Mimic(мнемосхема)
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Mimic(мнемосхема)
Viewing 15 posts - 16 through 30 (of 38 total)
  • #705
    Evgen
    There is visualization. already configured. working. but not through the web browser. and only one computer.
    Visualization looks like a color change parameters when they go abroad. the movement of trolleys and their positioning and the like.
    How to display a ready-made visualization through RapidSCADA
    Тоже на русском.
    Есть визуализация. уже настроена. работает. но не через браузер. а только на 1 компьютере.
    Визуализация выглядит так изменение цвета параметров когда они выходят за границы. движение вагонеток и их позиционирование и тому подобное.
    Как вывести уже готовую визуализацию через RapidSCADA
    #706
    What technology is used for the visualization that is already done? Could you send a screenshot?
    #707
    Evgen
    https://yadi.sk/i/vV9eUHVAkRmW9
    Here screen (everything will remain, it is for the operators)
    used сodesнs ops and master SCADA
    change of color rendering.
    For perezentatsii will create another visualization
    (already drawn left to wait until an engineer when to make the switch, and will pave the cable)
    but I just do not want to paint all over again. just a lot of areas where you have to leave as is
    #708
    It seems you can not do without creating a new configuration similar to the existing.
    #709
    Evgen
    Hello!
    I have a new question
    Now screen
    https://yadi.sk/i/IodXoZnzkUtL9
    how to make a wider mimic?
    Editor schemes stretched the full width of the work area.
    Здравствуйте!
    У меня новый вопрос
    вот скрин
    как сделать мнемосхему шире?
    в редакторе схем растянуто на всю ширину рабочей области.
    #710
    Hi!
    If you use the same monitor, check scaling in your browser.
    #711
    Evgen
    I have a question again.
    How to make that sign (Figure) changes from “closed” to “closed”
    under the condition x> 0 (Works) x = 0 (not working)
    #712
    Evgen
    How to make that sign (Figure) changes from “Works” to “not working”
    IRDP condition x> 0 (Works) x = 0 (not working)
    the editor of schemes, I’m interested in how to implement it!
    #713
    Evgen
    Thanks I figured, everything just need a close look
    #723
    Evgen
    Hello!
    I am interested in the possibility of a Rapid SCADA following graphic visualizations
    1 thermometer, and that the band would correspond to the real DATA
    2 fan rotation when the real ventilyato work and do not rotate when the real is not working
    3 pointer speedometer
    and in general how to do in Rapid SCADA visualization with the movement?
    Thank you in advance!
    P.S. If this topic already raised give the link
    #726
    This is the frequent question. In the current version 4.5 you can display a gauges and meters using a set of images. Each image for the each value. Otherwise use text labels. In the spring of 2016 we are going to create a new SCADA-Web with required graphical components.
    #728
    Evgen
    Hello!
    I have another question.
    How to display a single chart several variables?
    Here are examples of such plots.
    https://yadi.sk/i/IT3dTZrikZtqk
    https://yadi.sk/i/lJXuDFtvkZtri
    #732
    1. The additional component ChartList
    scada chartlist
    2. Component for Charting
    These components are commercial. I will send you an offer by e-mail.
    #735
    Evgen
    Thank you!
    If management wants will order this component.
    #747
    Evgen
    Здравствуйте!
    У меня опять вопрос. Как сделать следующее, есть датчик тока(к примеру) и необходимо с точностью до секунды отслеживать его включение, выключение и токи которые выходят за нижнее и верхнее ограничения? И что бы эти данные выводились в событиях к примеру.
