Hello
I checked PlgMap.xml location and it’s OK. It is in Instances – Default – Webstation – Configuration. Webstation version is 6.2.1.0 and PlgMap version is 6.1.1.0. You can see all in this print screen:
Thank you for the screenshot.
I suppose, it’s needed to upgrade ScadaWeb to version 6.2.2.0.
The currently used versions of the plugin and the web app use the different APIs.
