Forum Home › Forums › Communicating with Devices › Modbus › Logging fast I/O
- This topic has 30 replies, 3 voices, and was last updated 11 months, 2 weeks ago by
August 20, 2025 at 9:56 am #16889
zarsss
ParticipantI guess, it is time to give up. I keep trying to understand it, but no success so far.
August 20, 2025 at 11:15 am #16890
manjey73ParticipantWell, you need to try it a few times to figure out how to set it up 🙂
Again, regular Charts may not be able to show data, except from the Minute Archive, I did not check, since I always use ChartPro.
August 20, 2025 at 11:16 am #16891
manjey73ParticipantHowever, you can always use additional utilities to check for records.
August 20, 2025 at 11:27 am #16892zarsss
ParticipantI have purchased ChartPro plugin, but there’s so many unknown details for me. For example, do I need to install a PostgreSql to have ModArcPostgreSql arcive working? How do I configur ChartPro plugin? Or do I actually need to? Does archive name, I have created, has to be visible in the channels list?
Literally, I am just clicking around without knowing if I’m on the right path or not.August 20, 2025 at 11:28 am #16893zarsss
ParticipantThen there will another black hole for me – scripting and creating decent schematic.
August 20, 2025 at 11:31 am #16894
manjey73ParticipantThe archive is recorded using the selected mask. The archive name is not displayed in the channels. Or do you already mean on the chart itself?
You must manually configure additional configurations for the Pro Charts.August 20, 2025 at 11:35 am #16895
manjey73ParticipantWhat do you mean by scenarios?
As for mnemonics, I chose the SVG creation method for myself, but sometimes it’s a bit tedious. At the same time, I do not use graphic editors practically. I draw in AutoCAD in different colors, print to PDF with the selected size (adjust to the image) and use an online converter from pdf to svg. Then I edit the styles with my hands (I change the colors, line thicknesses, etc.)
August 20, 2025 at 11:39 am #16896
manjey73ParticipantIf it opens for you, translate this post.
Again, if you have an opening.
August 20, 2025 at 12:08 pm #16897zarsss
ParticipantYou must manually configure additional configurations for the Pro Charts.
Is there any sort of manual how to do so?As per design, I would want to display use several gif files to show different states of machine. I have made one gif file so far, but haven’t looked at how to replace one gif with a different one depending on machine conditions. For example, if there is no air pressure, air valve on the machine is flashing red. Something like that.
August 20, 2025 at 12:56 pm #16898
manjey73ParticipantBased on the examples in the system only. And according to the documentation
https://rapidscada.net/docs/en/latest/modules/plg-chart-pro
To use multiple files depending on the conditions, set a Dynamic drawing and add a Collection. There is an option to create conditions for channel values.
August 20, 2025 at 1:43 pm #16899
MikhailModeratorPlease don’t mess up many topics in one. Create new topic for other questions.
Archive kind should be set to historical.September 29, 2025 at 7:41 am #17109zarsss
ParticipantHi. I am returning to try and solve this.
Is there any specific requirements to set up an archive? I have tried to make one and despite it is shown in the Administrator, I also noticed that I don’t have a physical file in the SCADA folder.September 29, 2025 at 8:58 am #17111
Please provide screenshots of the settings and the error. Also check the archive status in ScadaServer.txtSeptember 29, 2025 at 9:37 am #17113zarsss
ParticipantSeptember 29, 2025 at 10:32 am #17114zarsss
ParticipantPlease keep in mind that most of the time, I am guessing what I am doing.
