Skip to content
Rapid SCADA Forum
Technical support of Rapid SCADA users
  • Forum Home
  • Rapid SCADA
  • Contact
external application requesting sacada data
Forum Home › Forums › Development and Integration › external application requesting sacada data
  • This topic has 25 replies, 4 voices, and was last updated 2 years, 5 months ago by zzz.
Viewing 11 posts - 16 through 26 (of 26 total)
← 1 2
  • April 19, 2024 at 12:16 pm #14446
    JW
    After trying all the methods, still not working.
    Then I downloaded the ScadaTestClient again, this time running it, then it worked.
    There is a windows warning about the unsigned application this time, never popup before, then after clicking yes, it can run. not sure if it is relevant.
    April 19, 2024 at 12:49 pm #14447
    JW
    finally found the issue, in the password field of the xml, can not use the password copy from user table.
    need to use the password generated from the Project Tools -> Encrypt Password.
    April 19, 2024 at 1:15 pm #14448
    JW
    I am confused with the encrypted password meaning for the API.
    for the HelloWorld Project, default ScadaComm account
    Plain test pw = scada
    pw from user table = F9A226BC671CB198C7D83ADEA0B1F2B8
    pw from encrypt password tool = B9D0F030265751578B00E9801C69320C
    secrete key = 0E063D581B1DB27B8E984993DED65CE99284A706756C706C7F3B12C44BD55D4D
    for the API 0x0002 login, a field say encrypted password, does it mean the pw from encrypt password tool? or I need to do AES encryption again using pw from encrypt password tool with secrete key
    April 19, 2024 at 2:17 pm #14450
    JW
    Comparing the network traffic, I found a mismatch of the protocol document.
    for the 0x0002 function,
    for the field of username, password, instance,
    actually should be
    length of username (2bytes),
    username,
    length of password (2bytes),
    password
    length of instance (2bytes),
    instance
    April 22, 2024 at 7:50 am #14452
    You right. The Users table contains the password hash, while XML files contains encrypted passwords. Hash cannot be decrypted. Encrypted password can be decrypted. You can encrypt password with Administrator user interface.
    April 22, 2024 at 7:53 am #14453
    In the protocol, a string is encoded as
    Bytes 0…1 – the string length in bytes
    Bytes 2…N – the UTF-8 encoded characters
    Could you specify what should be updated in the document?
    April 23, 2024 at 1:20 am #14457
    JW
    my mistake, misinterpreted the string in the doc, the string format description is correct.
    April 23, 2024 at 8:56 am #14460
    OK
    April 23, 2024 at 4:01 pm #14461
    JW
    I get most command done except the login…
    use wireshark captured 3 login data, the “Encrypted Password String Bytes” are different each time.
    02003d000000cce90c32cd62e16f020009005363616461436f6d6d20004244383437323932323946453046443831343932394339393445354132393430000000000000
    02003d000000e7bc670599955ad1020009005363616461436f6d6d20004343464338394230304237383246353231344434343837434431304341354545000000000000
    02003d0000006c50d7e367885fa3020009005363616461436f6d6d20003631453934424138324433453145363036323643313743374236383633334339000000000000
    So the string bytes should be not directly the “Encrypted Password encrypt password tool”.
    Some further encryption operation has been done to the password before packing it into bytes.
    Is there any instruction on this?
    April 23, 2024 at 5:10 pm #14462
    Yes. The protection algorithm encrypts password differently. Otherwise, someone can sniff packets and login.
    Check the ScadaClient and ClientBase source code.
    May 29, 2024 at 5:08 am #14553
    zzz
    Since there doesn’t seem to be any mention of the session id, it may be worth mentioning that the password encryption is initialized with the sess_id.
    Here is how I did it in my current client.
    def Encrypt(s: str, sec_key, sess_id) -> str:
        ct = EncryptBytes(s.encode("UTF8"), sec_key, sess_id)
        return binascii.b2a_hex(ct).decode("ascii").upper()
    def EncryptBytes(bstr:bytes, secretKey, sess_id):
        # generate iv from sess_id
        iv = bytearray(IVSize)
        sessBuf = struct.pack("q",sess_id)
        sessBufLen = len(sessBuf)
        for i in range(0, IVSize):
            iv[i] = sessBuf[i % sessBufLen]
        #print("gen_iv=")
        #hexdump(iv)
        # encrypt byets
        padder = padding.PKCS7(128).padder()
        cipher = Cipher(algorithms.AES(secretKey), modes.CBC(iv))
        encr = cipher.encryptor()
        bstr = padder.update(bstr) + padder.finalize()
        ct = encr.update(bstr) + encr.finalize()
        return ct
← 1 2
Log In
Log In
Register Lost Password
Search Forums
Forum Statistics
Registered Users
844
Forums
18
Topics
2,306
Replies
13,278
Topic Tags
1,114
Empty Topic Tags
298
Recent Topics
  • Chart Pro Plugin – Possible to annotated Min and Max Value?
  • PlgMimSVGAnimationJP
  • Inaccuracy in the Rapid SCADA Documentation
  • OPCUA Server Certificate Period
  • Hex Command
Copyright © 2025 Rapid SCADA
