Forum Home › Forums › Understanding the Software › Data Exporting
- This topic has 25 replies, 3 voices, and was last updated 2 years, 9 months ago by
November 22, 2023 at 8:20 am #13696
MikhailModeratorIf the module is active, check it log files.
November 28, 2023 at 7:07 am #13718KeanoC
ParticipantHere are my logs after making the connection but i dont seem to be getting any data automatically exporting to my db.
2023-11-28 08:11:09 [B100][B100$][ACT] Server 6.1.1.1 started
2023-11-28 08:11:09 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
2023-11-28 08:11:09 [B100][B100$][ACT] Start logic processing
2023-11-28 08:11:09 [B100][B100$][ACT] The configuration database has been read successfully
2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for archiving: 335
2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for sending commands: 0
2023-11-28 08:11:09 [B100][B100$][ACT] Compile the source code of scripts and formulas
2023-11-28 08:11:09 [B100][B100$][ACT] Added the following dependencies:
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\netstandard.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.ComponentModel.Primitives.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Console.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Diagnostics.Process.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Linq.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Private.CoreLib.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Runtime.dll
C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll
C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll
2023-11-28 08:11:10 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
2023-11-28 08:11:10 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
2023-11-28 08:11:10 [B100][B100$][ACT] Archive Cur initialized successfully
2023-11-28 08:11:10 [B100][B100$][ACT] Archive Min initialized successfully
2023-11-28 08:11:10 [B100][B100$][ACT] Archive Hour initialized successfully
2023-11-28 08:11:10 [B100][B100$][ACT] Archive Events initialized successfully
2023-11-28 08:11:10 [B100][B100$][ACT] Start listener on port 10000
2023-11-28 08:11:10 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
2023-11-28 08:11:10 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
2023-11-28 08:11:54 [B100][B100$][ACT] Stop listener
2023-11-28 08:11:54 [B100][B100$][ACT] Listener is stopped
2023-11-28 08:11:54 [B100][B100$][ACT] Logic processing is stopped
2023-11-28 08:11:54 [B100][B100$][ACT] Server is stopped
2023-11-28 08:11:57 [B100][B100$][ACT] Server 6.1.1.1 started
2023-11-28 08:11:57 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
2023-11-28 08:11:57 [B100][B100$][ACT] Start logic processing
2023-11-28 08:11:57 [B100][B100$][ACT] The configuration database has been read successfully
2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for archiving: 335
2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for sending commands: 0
2023-11-28 08:11:57 [B100][B100$][ACT] Compile the source code of scripts and formulas
2023-11-28 08:11:57 [B100][B100$][ACT] Added the following dependencies:
2023-11-28 08:11:58 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
2023-11-28 08:11:58 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
2023-11-28 08:11:58 [B100][B100$][ACT] Archive Cur initialized successfully
2023-11-28 08:11:58 [B100][B100$][ACT] Archive Min initialized successfully
2023-11-28 08:11:58 [B100][B100$][ACT] Archive Hour initialized successfully
2023-11-28 08:11:58 [B100][B100$][ACT] Archive Events initialized successfully
2023-11-28 08:11:58 [B100][B100$][ACT] Start listener on port 10000
2023-11-28 08:11:58 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
2023-11-28 08:11:58 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
2023-11-28 08:12:01 [B100][B100$][ACT] Session with ID -275528625156651192 created
2023-11-28 08:12:01 [B100][B100$][ACT] Client 127.0.0.1 connected
2023-11-28 08:12:01 [B100][B100$][ACT] User ScadaComm is successfully authenticated
2023-11-28 08:12:03 [B100][B100$][ACT] Client 127.0.0.1 disconnected
2023-11-28 08:12:04 [B100][B100$][ACT] Session with ID -2293832663858227796 created
2023-11-28 08:12:04 [B100][B100$][ACT] Client 127.0.0.1 connected
2023-11-28 08:12:04 [B100][B100$][ACT] User ScadaComm is successfully authenticated
2023-11-28 08:13:53 [B100][B100$][ACT] Created event with ID 7306392348303855930 and channel 304
2023-11-28 08:53:24 [B100][B100$][ACT] Created event with ID 7306402531278643967 and channel 304November 28, 2023 at 12:10 pm #13723
MikhailModeratorThe above is the content of ScadaServer.log
Log files of the module are ModDbExport*.* in the same directory.-
This reply was modified 2 years, 11 months ago by
November 28, 2023 at 12:38 pm #13727KeanoC
ParticipantHere is a screenshot I took of what I assume your talking about. My export logs dont seem to be apearing
November 28, 2023 at 12:44 pm #13728KeanoC
ParticipantAnd yes my module is active
November 28, 2023 at 12:55 pm #13729KeanoC
ParticipantFound the logs this is how they look.
November 29, 2023 at 9:34 am #13739
MikhailModeratorYou could start with providing correct MySQL connection settings.
Also check ModDbExport*.txt files.November 30, 2023 at 6:42 am #13746KeanoC
ParticipantThe 003 is from the mysql which im no longer using but the 002 has the correct string
November 30, 2023 at 9:01 am #13749
MikhailModeratorIn the module options disable Archive Replication for testing. Then check the log file.
January 5, 2024 at 6:09 pm #13894Tecneira_monitoring
ParticipantHi there Mikhail,
I’m trying to export some channels values to a MySQL DB. By now I’ve already created a query in DBExport module and could export some of my project channels. The problem is that when I want to add new channels to query (channels 100000 to 100015 for example) this ones are not exported by Rapid Scada to my database.Here is an example of the query:
QueryAnd here a print of what is collected in the database:
MySQL_DBThank you in advance
January 6, 2024 at 10:12 am #13897
I suggest to create a separate trigger that exports only the channels that are not exported. It would be useful to create a new table in the DB for them. It can help to realize the cause of the problem. -
