Forum Home › Forums › Uncategorized Issues › Daily Archive
- This topic has 30 replies, 3 voices, and was last updated 1 year, 9 months ago by
January 16, 2025 at 4:47 am #16010
Hcinarli
ParticipantExcept for the table editor, where can I do this in rapid, in the logic of the table editor or can an improvement be made in the table editor, as in the hours related to the periodic keeping of daily and monthly data?
January 16, 2025 at 5:37 am #16011
manjey73ParticipantWell, in the current version, probably draw your own table in a mnemonic scheme. Alternatively, you can create your own web page where you can use js to pull out the data you need and connect it as a view.
January 16, 2025 at 6:43 am #16012Hcinarli
ParticipantI thought about designing a schema for daily data, but how will I get the data I want for the channels I want?
January 14, 00.00 Value
January 15, 00.00 Value
January 16, 00.00 valueDo you have an idea that will continue or renew itself periodically?
January 16, 2025 at 6:47 am #16013
manjey73ParticipantIf you do it in the form of a mnemonic, then you just need Calculation channels where you will copy daily data.
But if you want flexibility, by analogy with regular tables, then you either need to refine them or make your own table plugin.
Another way, as mentioned above, is to try a Flexible report and output it in HTML from the view.January 16, 2025 at 6:52 am #16014
manjey73ParticipantTry to figure out the ElasticReport settings. I didn’t get what I expected from him, but in your case it might be different.
This reply was modified 1 year, 9 months ago by
manjey73.
January 16, 2025 at 6:53 am #16016Hcinarli
ParticipantI will check for flexibility, so how should the channel properties be if I do it as a reminder, if possible, can you configure and send 1-2 channels in the project file I sent as an example?
January 16, 2025 at 7:07 am #16017
manjey73Participantunfortunately, I didn’t really figure it out myself 🙂 All the time, when I try to deal with him, I don’t have enough patience. And the primitive that I wanted to make didn’t suit me, because it doesn’t support it.
January 16, 2025 at 1:47 pm #16021
MikhailModeratorThe screenshot on Google Drive is not public.
January 16, 2025 at 1:49 pm #16022
MikhailModeratorJanuary 16, 2025 at 1:50 pm #16024Hcinarli
ParticipantSorry I updated permissions you can now access google drive.
January 17, 2025 at 11:01 am #16032
MikhailModeratorThere are no screenshots at the link. This conversation seems useless. I’m about to close the topic.
January 17, 2025 at 11:15 am #16033Hcinarli
ParticipantI have already shared screenshots before, I have a sample project file in driveda so that you can check the operations I have done.
Screenshots :
https://ibb.co/Sr49STj
https://ibb.co/GczdZskThe result I get in the table view is only the current data “current” values as in the default settings, so no other values are registered.
Hcinarli.
January 17, 2025 at 1:05 pm #16035
manjey73ParticipantChange my Elastic Report test configs there chlNum to your own and try it.
January 18, 2025 at 2:01 pm #16037Hcinarli
ParticipantCan you please explain how I should test the xml files you sent, I dropped the files into the web config and wiew and uploaded them, but I don’t know how I should use them or whether I’m doing the right thing, can you explain step by step if possible?
January 18, 2025 at 2:16 pm #16038
manjey73ParticipantWell, you need to install ElasticReport first.
And following his example, the xml in the sent ones should be replaced with the channel numbers that you have in the project. See how it will all be displayed in html.
I didn’t understand much, to be honest. There you can change the names of channels, what exactly to output, and so on. -
