Convert historical data from V5 to V6
Forum Home › Forums › Understanding the Software › Convert historical data from V5 to V6
Viewing 5 posts - 16 through 20 (of 20 total)
  • #14331
    kcks66
    Hi Mikhail,
    > However, why don’t you use *.dat format as a secondary to make the system more reliable? Yes, I will consider this.
    Thanks for your suggestion. Since my project is non-commercial value, I would like to explore > Deploy an additional instance of Rapid SCADA and use Rapid Gate module to transfer data from the additional instance to the main instance of Rapid SCADA.
    I will get another PC to setup another Rapid SCADA and load with all the *.dat files. Will try it out and raise questions when the setup is ready.
    #14337
    Thank you for the update. Please tell about the results.
    #14397
    kcks66
    Hi Mikhail,
    I finally managed to setup another PC with Rapid SCADA configuration exactly same with the target PC Rapid SCADA. I managed to login target PC via RapidGate. The next step is pls advice for which part I should configure?
    https://ibb.co/L00KSv0
    This Historical Data Transfer Option?
    https://ibb.co/GtXdzWb
    This Achieve Replication Option?
    FYI, all channels from Target PC and RapidGate PC are configured exactly same Channel ID. Target PC was configured with Archives set at ModArcPostgreSql.
    #14400
    Please create a new topic to discuss Rapid Gate. This topic is about data conversion from v5 to v6.
    #17409
    ProjConv5to6_dotnet8
    HistConv5to6_dotnet8
    EventConv5to6_dotnet8
    • This reply was modified 10 months, 2 weeks ago by Mikhail.
