Channel Read Bits
Forum Home Forums Understanding the Software Formulas Channel Read Bits
Viewing 10 posts - 16 through 25 (of 25 total)
  • #15056
    In version 6 you can try creating a format to display value in binary form. Format code would be B
    #15057
    Also hexadecimal format would be useful.
    #15060
    rapidscadaaks
    Many Thanks
    #15062
    rapidscadaaks
    Hi Mikhail
    I am using GetAnyBits below:
    public double GetAnyBits(double val, int n, int mask = 1)
    ulong ulVal = (ulong)val;
    return (ulVal >> n) & (ulong)mask;
    The issue is of format.
    When I use Hexadecimal, vales are same as General with addition of 3 places of decimal which are zeros. I could not understand how to try the B Format as there is no option for B. I am using version 6.
    #15063
    Oops, I didn’t know there was a binary display format 🙂
    You need to add option B for the format and test it.
    Auxiliary Tables – Formats
    Custom Formats
    • This reply was modified 2 years, 1 month ago by manjey73.
    #15066
    Something is not working to display the number in binary form. It shows !!! on the graph, in the table ---
    #15067
    Chart Pro falls on the string variable – a white screen 🙂
    #15070
    It was added in .NET8. I’ve never tried it before.
    It cannot display graph of a string.
    #15071
    In the Formats table add a new format. I’m not sure that B will work, however, it worth to try.
    #15101
    Binary format will be supported in the next release.
