Any questions about Rapid SCADA and Raspberry Pi
Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Any questions about Rapid SCADA and Raspberry Pi
Viewing 15 posts - 16 through 30 (of 89 total)
  • #414
    ASA
    Ok
    How do you configure it ?
    Is it with windows then copy across if so what files?
    asa
    #415
    You definitely right.
    After configuring using Windows you should copy the content of the follownig folders:
    C:\SCADA\BaseDAT
    C:\SCADA\Interface
    C:\SCADA\ScadaComm\Config
    #428
    ASA
    Ok the transferring of the files worked my next problem
    I have lost connection to my device (rs232) I am useing a usb to rs232 converter the rpi says it’s device ttyUSB0 what am I doing wrong?
    Asa
    #430
    Is the port successfully opened by SCADA-Communicator?
    #433
    ASA
    According to the logs com1 to com9 all had the same
    Error
    Error opening serial port no such file or directory
    #436
    Specified port name is wrong. What is the full name of ttyUSB0 is listed by Raspberry Pi?
    #437
    ASA
    Ok how do you get that?
    #438
    ls /dev/tty*
    #439
    Use should use /dev/ttyUSB0
    #440
    ASA
    It is listed on the list as /dev/ttyUSB0
    Asa
    #441
    ASA
    We’re should we use it?
    #442
    ASA
    Are you able to send a example com config page?
    #444
    It is here
    #446
    ASA
    First off thank you for your help to date!
    I have the usb sending commands to my plc
    My new problem it’s the wrong ones on windows the scada send out 64 04 70 07 00 16 D3 30 this works
    On pi it’s 64 04 B0 10 90 71 07 FE for some reason it’s changed I have checked the scadacomm config files and they appear to be the same what’s your thoughts
    Asa
    #447
    Please send a larger piece of the communication log.
