Forum Home › Forums › Understanding the Software › Sending Int16 or Uint16 as command value
- This topic has 18 replies, 2 voices, and was last updated 10 years, 11 months ago by
September 17, 2015 at 3:14 pm #494
dejan
ParticipantHi Mikhail,
I am trying to send 2-byte integer as command value to the Modbus device. In “Output channels” table for the specified output channel I have declared “Standard” as “Command Type”. As far as I understand in this case the value is being sent as a 4-byte floating point number. Can’t figure out how to send the value as a 2-byte integer. Moreover, by checking the Communicator log i see that the actual value sent is always 00 00 regardless of the value entered in the Value box.
Please help,
DejanSeptember 17, 2015 at 7:01 pm #495
MikhailModeratorHi Dejan,
Your configuration seems correct. In the new version of SCADA-Communicator commands are displayed on the Device Data page. What is the command value there?September 18, 2015 at 7:31 am #505dejan
ParticipantI’m still using the previous version 4.4 of Communicator and I can’t see command values there. Regardless of that, in “Standard” command type description provided in Administrator app, it says that for “Standard” type, command parameter is floating point number. And it seems that value entered is treated as such. So, I have no idea how to send an integer as command value.
If it is necessary, I will install the latest version of Rapid Scada.
Dejan
September 18, 2015 at 7:46 am #506
Double value is trancated by Modbus driver. Value type is not a problem.
You could update SCADA-Communicator only. It’s easy. Make backup copy. After updating, copy the config folder and check the settings.September 18, 2015 at 8:21 am #507dejan
I’ve installed the new Communicator. Now, when I send any value I get this log in Device Data / Commands:
| 2 | 18/09/2015 10:14:55 | Command: type = Standard, device num. = 1, value = N3 |
What does N3 mean?
September 18, 2015 at 8:55 am #508
MikhailModeratorIt is a displaying bug )
It was fixed yesterday, but not published. Sorry. I shall do it till the midnight.September 18, 2015 at 9:11 am #509dejan
Thanks for your replies, but I still don’t have the answer to my original question – what to configure and how in order to send a value as 2-byte integer to a Modbus device.
September 18, 2015 at 9:20 am #510
MikhailModeratorFirst of all, you should find where the value got lost.
Please remind me, if you send command by SCADA-Communicator directly, it works OK?September 18, 2015 at 9:47 am #511dejan
ParticipantNo, it doesn’t. I can only correctly send binary data from communicator.
September 18, 2015 at 9:54 am #512dejan
ParticipantFor example, if I send a simple number like 100 or 200, my modbus device receives 0. If I send binary hex data 00 64 (=100 decimal) my device receives 100.
All that done directly from communicator.September 18, 2015 at 9:55 am #513
MikhailModeratorHow the command is configured in the device template? Send a screenshot, please.
September 18, 2015 at 10:30 am #515dejan
ParticipantSeptember 18, 2015 at 10:31 am #516dejan
Participanthttps://drive.google.com/file/d/0B6UnLsN1oaMgM05RcWhYdVFKelk/view?usp=sharing
In my machine I’m using Modbus function 16 for writing to holding registers. That’s why “Multiple is checked” to tell communicator to use function 16 instead of function 06.
This reply was modified 10 years, 11 months ago by
dejan.
September 18, 2015 at 11:44 am #518
MikhailModeratorYou need to create your own function in Formulas table which converts double input value to the array of bytes. Then use your formula in Output channels table.
Also you need to upgrade SCADA-Server to 4.5.September 18, 2015 at 11:46 am #519dejan
ParticipantOK, got it.
