SCADA-Scheme Editor does not work
Forum Home › Forums › Installation Issues › SCADA-Web Installation › SCADA-Scheme Editor does not work
Viewing 15 posts - 1 through 15 (of 18 total)
  • #165
    Reply to Fernando:
    Please open demo scheme using SCADA-Web and check if Silverlight work’s well in browser. If Silverlight installation is needed, install it. If scheme works properly, write about it in this topic.
    • This topic was modified 11 years, 7 months ago by Mikhail.
    #167
    Fernando
    I can not open ScadaWeb
    “D:\IMAGENES\Screenshots\Captura de pantalla (126).png”
    #168
    Could you upload your screenshot to the web using image hosting, for example, postimage.org ? I can’t view the image from drive D of your PC.
    #823
    Wan
    I have some problem with ScadaScheme (ScadaSchemeEditor)
    Error is “WCF service error: the remote server returned an error: NotFound”
    can you help me.
    Thanks!!
    #824
    Wan
    my ScadaScheme error: Не удалось загрузить схему
    #825
    Please check that HTTP Activation feature for .NET 4+ is checked on:
    #826
    Wan
    Thanks you.
    but my pc is win7,so I don’t have NET 4+ in my windows features ,only have net 3.5.1
    so win7 can’t run ???
    I have try install net 4+,but my windows features can’t find .net 4+ .
    Do you have others method?
    #827
    In Win 7 the required feature is included in .NET Framework. You don’t need to tick checkbox.
    Please check that application pool with .NET 4 is chosen for Scada web application. Use IIS Manager for this purpose.
    #830
    Does it help?
    #831
    Wan
    no,my pronlem also exist ..
    #832
    Could you post a screenshot of http://localhost/scada/scheme/ScadaSchemeSvc.svc ?
    #833
    Wan
    Ошибка при работе приложения: 主機 (‘IntegratedWindowsAuthentication’) 上設定的驗證配置不允許繫結 ‘BasicHttpBinding’ (‘Anonymous’) 上設定那些配置。請確認 SecurityMode 已設定為 Transport 或 TransportCredentialOnly。此外,透過 IIS 管理工具、ServiceHost.Authentication.AuthenticationSchemes 屬性,在應用程式組態檔的 <serviceAuthenticationManager> 元素變更此應用程式的驗證配置、更新繫結上的 ClientCredentialType 屬性或調整 HttpTransportBindingElement 上的 AuthenticationScheme 屬性可以解決此問題。
    #834
    Wan
    I deleted my pc all .net framework and install .net framework 4.0
    enter: http://localhost/scada/scheme/ScadaSchemeSvc.svc
    my screenshot content is
    “Application error: Security settings for this service require ‘Anonymous’ Authentication but it is not enabled for the IIS application that hosts this service.”
    #835
    Please open you Windows Features window again, expand Internet Information Services node and subnodes and send me a screenshot. I’m going to check what subitems are installed.
    #836
