Convert historical data from V5 to V6
Forum Home Forums Understanding the Software Convert historical data from V5 to V6
Viewing 15 posts - 1 through 15 (of 20 total)
  • #14271
    kcks66
    Hi Mikhail,
    Currently I am in the works to migrate Rapid SCADA from v5.8.4 to v6.2.0. I had done manual configure all channels in v6, right now is the time to migrate historical data from v5 to v6.
    I downloaded from your utilities tools-v6 HistConv5to6_dotnet8 and extracted. I double click the HistConv5to6 application file somehow looks like a command prompt window pop up then automatic close down.
    Pls advice for the steps. Thank you.
    #14275
    You should run cmd first. Then execute the *.exe in the command prompt.
    #14280
    kcks66
    Hi Mikhail,
    I got the converter to run. However, I got many errors. The converter stop when encountered error. I need to remove those error .dat files and re-run the converter.
    https://ibb.co/wQHkqGF
    Is there a way to make the converter automatically re-run by skipping errors .dat files?
    By the way, why there is some error from v5 .dat file?
    Pls advice and thank you.
    #14291
    It is important to find the cause of the error. May be those files contains correct and useful data. Could you open the problem files in the Administrator app to view data and try to realize why they can cause the error?
    #14292
    kcks66
    Hi Mikhail,
    I can see the error .dat file contain two data per one minute, if compared to other success .dat file contain one data per minute:
    https://ibb.co/10rWGDy
    Any .dat file with more than 1440 will be treated as error.
    #14299
    Try the updated converter. Send a screenshot of its work, please.
    #14301
    kcks66
    Hi Mikhail,
    I can see the new converter can continue to run after encountered those data more than 1440 per day.
    https://ibb.co/34tkBJV
    #14302
    kcks66
    Hi Mikhail,
    Previous Rapid SCADA v5 I use .dat as my main achieve. Right now after I migrated to v6 I want to use ModArcPostgreSql as my main achieve.
    Those .dat files from v5 I used the converter to convert to v6 .dat files format, can be trend by modArcBasic only, right?
    Pls advice for what should I do after I set ModArcPostgreSql as my main achieve and still can trend back those converted historical data previously from v5?
    • This reply was modified 2 years, 4 months ago by kcks66.
    #14304
    Yes.
    Using Chart Pro, you can create a chart profile to open data from *.dat archive. Reports also support choosing an archive.
    However, may be in your case it is better to use PostgreSQL as a secondary archive.
    #14306
    kcks66
    Hi Mikhail,
    I would like to explore all of these advice.
    1) How shall I configure the chart profile to open data from *.dat archive?
    https://ibb.co/Gpz254z
    2) Am I need to enable/true the below?
    <!– User can select archive –>
    <SelectArchive>false</SelectArchive>
    3) I need to active both set of Achieve like below?
    https://ibb.co/RPkhFbf
    #14310
    1) Create a copy of ChartPro.xml, for example, PlgChartPro_Profile2.xml
    Add a new line into ChartPro_Config.xml
    <Profile fileName="PlgChartPro_Profile2.xml">Profile 2</Profile>
    #14311
    2) In Elastic Report, use SelectArchive and/or DefaultArchive
    3) Yes. Activate archives that are in use.
    #14314
    kcks66
    Hi Mikhail,
    Thanks. I tried all of them and they worked accordingly.
    After I discussed and showed to the system users, we finally decided to use PostgreSql as only one achieve as main achieve.
    My next step is to migrate all the *.dat files (in v6 format already) into Postgresql database. Pls advice any faster or easier way to do such migration?
    #14317
    It’s up to you. However, why don’t you use *.dat format as a secondary to make the system more reliable?
    #14318
    Currently, there is no ready to use converter. 2 approaches come to my mind:
    1. We can develop a converter by a contract.
    2. Deploy an additional instance of Rapid SCADA and use Rapid Gate module to transfer data from the additional instance to the main instance of Rapid SCADA.
