Forum Home › Forums › Communicating with Devices › Modbus › Connecting Devices Using Modbus Protocol
- This topic has 16 replies, 3 voices, and was last updated 6 years, 7 months ago by
manjey73.
January 24, 2020 at 8:38 pm #6442
joeh6966
ParticipantI viewed your video on YouTube, https://www.youtube.com/watch?v=Y4t9_qICKjc&list=PLeyJvzEKXs5DioKHdYWdy3kr6EMIJax0W&index=7 , on configuring Modbus 2 times and am still lost due to my difficulty understanding your accent and how fast you go.
So, I reviewed and tried to learn how using the documentation. I cannot even get the test project with KpModbus_Adam6015.xml to run. I get “error” instead of normal and communication error.
I previously just went for my end game by trying to configure Rapid SCADA to read and log 4 registers (40802-40805) on my Sentron PAC3200, and then try to get a decimal from those four 2 byte registers.
Does my other program polling the PAC3200, powerconfig, have to be offline to communicate? I tried that with no change.
Are you able to get me on the right track, please?January 25, 2020 at 11:22 am #6443
MikhailModeratorI cannot even get the test project with KpModbus_Adam6015.xml to run. I get “error” instead of normal and communication error.
If you provide screenshots, I will try to help you.
If you use RS-485, the only one application can poll.
If you use TCP, it depends on a particular device. Many devices support only 1 connection.January 27, 2020 at 4:12 pm #6446joeh6966
Participanthttps://ibb.co/SVjQcc6
https://ibb.co/bsLn2MJ
Imgur not working today.
I’m using ethernet to my router from the PAC3200.January 28, 2020 at 2:14 pm #6448
MikhailModeratorThe provided screenshots don’t contain any error.
Look for communication line log.January 29, 2020 at 8:25 pm #6451joeh6966
ParticipantI got through your video and succeeded to get the same results that you did.
However, I don’t see how to pick reading and writing times and how to save them to a log file.
I only need to read 4 registers 5 times a day.
Can I do that and have them recorded into a log?January 30, 2020 at 7:04 pm #6453joeh6966
Participanthttps://ibb.co/Yf7Kjm9
https://ibb.co/hWt77bB
More success today.
I got the Line Log to work well by adjusting the Device Template to “double (8 bytes”.
Here is the Template snip. https://ibb.co/8N3g7nv
Now that Rapid SCADA communicates with the PAC3200 meter, I see that I get a Send command and a receive data that is 7 and 10 bytes. I can take the last 8 bytes and put them in a converter and get a decimal conversion in Wh.
I wish to get it to read and log once per hour and save it in a file that I can then convert to decimal, or convert to decimal first and save that once per hour.
Do I need to try out the Automatic Control Module to get what I want?January 30, 2020 at 8:02 pm #6454
manjey73ParticipantThe idea is to write a formula and add the value to a file once an hour without using the auto control module
January 30, 2020 at 11:17 pm #6455joeh6966
ParticipantI guess that there is no built-in 64 bit double precision conversion in Rapid SCADA.
It seems a daunting task to create my own.
I can get a reading every hour and see them in Line Log, but there is all of the other communication messages in the way.January 31, 2020 at 3:20 pm #6458
MikhailModeratorI only need to read 4 registers 5 times a day.
Set the period like written here to poll on time.
January 31, 2020 at 3:22 pm #6459
MikhailModeratorDo I need to try out the Automatic Control Module to get what I want?
I think you should use formulas.
Do you get correct double value in Communicator?January 31, 2020 at 6:51 pm #6462joeh6966
ParticipantI think that setting the time will give me one reading at that time, but I need 4 daily weekdays at least. 7,11,17,19 And once a month I need readings on the weekend because it’s month end on my hydro bill. I think that using a period of 1 hour will cover my needs there.
As far as the formulas go, I get one reading of 4 two byte registers as I showed above in message 6453. I poll the 4 registers 802-805 with one request that is 12 bytes. The receive message is 7 and 10 bytes. So, the last 8 bytes out of the 10 is
41 6A 61 BD 78 64 40 98. When I type them into FP converter, I get the right answer in watt-hours, but the converter had to do 3 swaps. Swap bytes, swap words, and swap double words.
I haven’t gotten into it yet, but I believe that after the swapping, they are converted to binary, and then they can be deciphered into decimal using the floating point system.
So, I might be able to do that using Libre Office Calc if it becomes necessary.
https://ibb.co/mqQnDZ0February 1, 2020 at 4:04 pm #6465joeh6966
ParticipantI set the time to 17:00:00 and the period to 01:00:00. It started to give the result every hour, but the even numbered readings, (18,20,22) have a communication error. And today I discovered that the Line Log is not working past 23:00:00 Jan.31. I expected it to run continuously.
https://ibb.co/1d5RYxF
https://ibb.co/37ctcwLFebruary 2, 2020 at 4:58 pm #6470joeh6966
ParticipantToday I am quite certain that my Rapid SCADA program is seriously compromised. Nothing works.
Project PAC3200 has my real IP address in it as I put in, but it also has 127.0.0.1 in the server stats. https://ibb.co/RyfDBQv I didn’t put that in.
The older project Modbus test now has info from the PAC3200 project that was created later. https://ibb.co/4p8b7Gz
More errors https://ibb.co/RyfDBQv
https://ibb.co/t3VQ1pN
https://ibb.co/kD8g7fZ
I guess that I can reinstall and start over again. I did get to where I wanted to with getting a reading every hour, but it missed every second hour and then crashed.February 3, 2020 at 7:57 am #6479
manjey73ParticipantFor example here you have everything perfectly readable
https://ibb.co/Yf7Kjm9When you read once an hour, you may need to uncheck “Stay connected” in the line settings. Actually, the problem is not in Scada, but perhaps in the communication settings, the settings of the device itself (it does not keep the socket open for so long and closes it by timeout), and so on.
February 3, 2020 at 8:23 am #6480
manjey73ParticipantIt seems that you don’t even need to rearrange the bytes, I entered a decimal number, and the calculator showed a different representation. “Most accurate representation”
http://floatingpoint.ru/value/double/416A61BD7388E68A
This reply was modified 6 years, 7 months ago by
manjey73.
