Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Automatic control with Raspberry Pi
- This topic has 19 replies, 4 voices, and was last updated 5 years, 10 months ago by
DikshaRaut.
April 2, 2019 at 1:46 am #5256
scadarapid
ParticipantHello
I use automatic control module of RaspidScada in window PC and it works very pretty.
so, now I am trying to use automatic control module in raspberry pi. I copy file from
window but it does not work with automatic controlI would like to ask you that can we use automatic control module raspberry pi.
and if it can use ,how we can do it.April 2, 2019 at 7:55 am #5257
manjey73ParticipantIt is also necessary to transfer the configuration of the module settings. And also buy a license for the module on RaspberryPi
April 2, 2019 at 1:10 pm #5258
Please send us the error messages from the module log.
April 25, 2019 at 6:25 am #5366scadarapid
ParticipantHi, I have questions about Raspberry Pi and Automatic Control Module.
1.How can we buy Automatic Control Module and set up in the Raspberry Pi?
2.Do we have to set up in the Computer PC with Automatic control Module before we transfer data to Raspberry Pi, Do we have to buy Automatic control Module in computer and in Raspberry Pi?.Thank You so much.
April 25, 2019 at 2:24 pm #5369
I suggest to wait a bit for Rapid SCADA 5.7.0. It will include a fully new Administrator which helps to easily configure the project on Windows and then upload to Linux. Likely in the next week the new version will be available.
In your case you need a license only for RPi.
April 26, 2019 at 9:44 am #5372scadarapid
ParticipantIn your case you need a license only for RPi.
How can I buy automatic control module for RPi cause i did not see this plugin on your site.
April 26, 2019 at 11:56 am #5373
MikhailModeratorDownload Automatic Control Module
Trial keys
New Rapid SCADA is here.April 26, 2019 at 1:16 pm #5374scadarapid
ParticipantHow can I get the computer the key in Raspberry Pi.
Now, I already finish to setup in PC and automatic control work perfectly on PC then, I transfer all file to Rpi everything works fine except the Automatic control module
the problem that i have found, I did not find computer code on Rpi to send to you to get trial key. how can I solve this problem. Please suggest.
thank you so much.
April 26, 2019 at 1:34 pm #5375
MikhailModeratorHow can I get the computer the key in Raspberry Pi.
You will find it in scada/ScadaServer/Log/ModAutoControl.log
April 29, 2019 at 1:50 am #5376scadarapid
ParticipantYou will find it in scada/ScadaServer/Log/ModAutoControl.log
My computer code on PC. it sames as my computer code on RPi. So Can i use this computer code on RPi.
CompCode.txt
April 29, 2019 at 5:54 am #5377April 29, 2019 at 7:44 am #5378scadarapid
ParticipantNow, I already get the computer code on Raspberry Pi so, if I buy the automatic control module and other plugins, it will require internet connection to use all plugins. Because my project do not have internet connection.
Thank you so much.
April 29, 2019 at 8:00 am #5380scadarapid
ParticipantOther question. If i format pc or change sd card on Raspberri Pi, i can still use plugin that i already bought?
April 29, 2019 at 2:35 pm #5382
MikhailModeratorif I buy the automatic control module and other plugins, it will require internet connection to use all plugins
Internet connection is not required.
April 29, 2019 at 2:36 pm #5383
MikhailModeratorIf i format pc or change sd card on Raspberri Pi, i can still use plugin that i already bought?
If you use the same RPi and keep a computer name unchanged, keys will work.
