Forum Home › Forums › Understanding the Software › Automatic Control Module integration
- This topic has 37 replies, 3 voices, and was last updated 5 years, 10 months ago by
hethongscada62.
August 8, 2016 at 11:42 am #1518
MohanadOdema
ParticipantHello,
I want to ask about something concerning the automatic control module;
Is there any possible way to import the trigger parameters into the scheme which I designed for my web page ?
August 8, 2016 at 1:13 pm #1519
Please describe your task in details. Why do you need it?
August 8, 2016 at 1:21 pm #1520MohanadOdema
ParticipantI have a time trigger for a certain command. I want to be able to change the time settings for this trigger from my Scada web page on a browser directly without the need to access the control module from the Scada Server.
August 8, 2016 at 3:05 pm #1521
MikhailModeratorIn this case you should use another approach:
Create an input channel as a flag and check time in the channel’s formula. Then create a trigger that fires on the flag value.
To change the timer counter according to a command you need an output channel.August 8, 2016 at 4:06 pm #1522MohanadOdema
ParticipantI’m not sure I understood that correctly. Does this flag value represent if the checked time is equal to the real time of my machine ?
I created the channel but how can I check time in a channel’s formula ?
August 8, 2016 at 5:29 pm #1523
MikhailModeratorDo you need a special time for sending command or just a period of doing it?
How accurately you need to define a time? Is it enough to set hour only or hour and minutes?August 8, 2016 at 5:31 pm #1524August 8, 2016 at 5:34 pm #1525
MikhailModeratorThe simple formula example:
double CheckTime() { DateTime nowDT = DateTime.Now; return nowDT.Hour == 1 && nowDT.Minute == 0 ? 1 : 0; }August 8, 2016 at 6:15 pm #1526MohanadOdema
ParticipantFor now I need a special time for sending the coomands.
In my design I want for example at 3:15 open relay switch and 3:30 close relay switch.
And later if I access my scada site I could cchange those times completely.
August 8, 2016 at 9:26 pm #1527MohanadOdema
ParticipantI’m sorry but I’m feeling lost with using the formulas. Am I supposed to enter the entire function you stated in the formula space as shown in the screenshot ?
August 9, 2016 at 8:11 am #1528
MikhailModeratorI mean that you should enter the whole CheckTime() function in Formulas table. Then enter just CheckTime() in Input channels table.
August 9, 2016 at 1:39 pm #1529MohanadOdema
ParticipantThat flag channel does not rise to one after several attempts from the code you gave me and even after changing the code and time multiple times.
double CheckTime()
if (nowDT.Hour==15 && nowDT.Minute==30)
{return 1;}
else
{return 0;}
}https://www.dropbox.com/s/su5wakulwacswzs/T1.png?dl=0
I dont know where the problem is and I still don’t know how I’m going to link the output channel to set the hour and minute values to those in the input channel.
August 11, 2016 at 8:16 am #1531
MikhailModeratorI didn’t write: you have to change channel type to Calculated real.
August 11, 2016 at 7:08 pm #1537MohanadOdema
ParticipantEven after I changed the channel type to calculated real, the channel value never becomes 1. I’ve tried a lot of approaches for the code and different types for the return variable and still nothing happened.
I even tried to use the existing function HourBeg() to see if it would return 1 at the beginning of an hour and it didn’t. I don’t know why none of the functions returns 1.
August 12, 2016 at 8:09 am #1538
MikhailModeratorIt’s strange. Did you pass the changes to Server and restart Server service?
Try simplifying the formula of an input channel.
First of all, try the formula: 1
Then try: DateTime.Now.Minute -
