Embedded mimic does not work
Forum Home › Forums › Understanding the Software › Mimics › Embedded mimic does not work
Viewing 15 posts - 1 through 15 (of 34 total)
  • #17965
    oley
    I created a MIM diagram with dynamic images/texts, and it works flawlessly.
    When I place it in a frame, as in another diagram, it is visible, but the dynamic elements don’t work: there is no text value and the image doesn’t change based on the channel value.
    #17967
    frame can block scripts. But in theory, if it works within the same domain, then everything should work.
    See what’s going on in debugging. Perhaps you just entered the wrong link to display in the frame.
    #17969
    oley
    I also put my scheme as dependency in my main view.
    Than I use it as a faceplate, set object and device id.
    This faceplate as standalone view work like a charm, but embedded faceplate does not display channel data in either text or images.
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Webstation 6.2.3.1 started
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Storage FileStorage 6.4.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgChart 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMain 6.1.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimic 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimic.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimicEditor 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimicEditor.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimBasicComp 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimBasicComp.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgScheme 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgStore 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgStore.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgWebPage 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgSchExtraComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchExtraComp.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgChartPro 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChartPro.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgDashboard 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgDashboard.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMap 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMap.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimExtraComp 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimExtraComp.dll
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimic: Add components from the PlgMimBasicComp plugin
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Check PlgMimExtraComp registration: Registration key is valid. Up to 10000 channels.
    Computer code: XXX
    Registration key: XXX
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgMimic: Add components from the PlgMimExtraComp plugin
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Check PlgSchExtraComp registration: Registration key is valid. Up to 10000 channels.
    Computer code: XXX
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Plugin PlgScheme: Added components from the PlgSchExtraComp plugin
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Check PlgChartPro registration: Registration key is valid. Up to 10000 channels.
    Computer code: XXX
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Check PlgDashboard registration: Registration key is valid. Up to 10000 channels.
    Computer code: XXX
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Check PlgMap registration: Registration key is valid. Up to 10000 channels.
    Computer code: XXX
    2026-06-05 10:34:37 [SCADA2][SCADA2$][ACT] Receive the configuration database
    2026-06-05 10:34:39 [SCADA2][SCADA2$][ACT] The configuration database has been received successfully
    2026-06-05 10:34:39 [SCADA2][SCADA2$][INF] The application is ready for operating
    #17974
    Check in the browser (show code) on the i-frame element
    #17976
    1. Screenshot of the mimic in the frame.
    2. Screenshot of possible errors in the browser console (by F12).
    #17978
    oley
    Screenshots:
    https://ibb.co/rRQNPVqK
    https://ibb.co/d0M3Rp12
    https://ibb.co/CyX0dzR
    https://ibb.co/PZLc83Jz
    https://ibb.co/qYb0g2gS
    It works partially – for example, it opens the chart for the correct channel – but the input channel isn’t working, meaning it doesn’t display the value in the Text field or the corresponding image in the Picture field.
    #17984
    http://localhost:5000/Object_13 What do you have there? the link for the frame?
    if I’m not mistaken, you need to place your pages in wwwroot\custom and the link will start with /custom/myHtmlPage.html
    Do you want to download the svg directly as a link? I’m not sure that’s going to happen.
    You have Images in the project tree, so you should add an image there. Or a more complicated way, use the ExtraMarkup component.
    #17985
    It is allowed to link to html in another resource, for example http://10.2.0.1:8081 but in this case, the javascript of another resource may be blocked inside the frame.
    • This reply was modified 5 months, 2 weeks ago by manjey73.
    #17987
    you probably made a mistake with the channel number on the trend.
    #17988
    did I understand correctly that when you remove frames from the mnemonic scheme, then the trend component starts working for you?
    #17989
    oley
    The frames at the right side with urls works fine. I have a service, which generates web pages on localhost.
    The problem is at the left side, that my faceplate does not react with channel data.
    If I take this faceplate as a standalone mimic view, it works fine.
    The faceplate embedded in another mimic view does not work (no channel data in or picture controls).
    #17992
    Now it’s clear, is there a problem with transferring channels if one *.mim is embedded in another?
    Is it possible to embed mim directly into mim? it seems that FacePlate and their exported properties are used for this.
    #17993
    oley
    Yes, exactly. Standalone mim works, but does not bind data as embedded in another mim.
    #17995
    it may not be possible to embed mim in mim. Try FacePlate
    #17996
    oley
    Simple example:
    mimic.mim:
    <?xml version="1.0" encoding="utf-8"?>
    <Mimic editorVersion="6.0.2.0">
      <Dependencies>
        <Faceplate typeName="Face" path="ProjTECH\PV\PV Szczecinek 5\Face.fp" />
      </Dependencies>
      <Document />
      <Components>
        <Text>
          <ID>1</ID>
          <AutoSize>True</AutoSize>
          <BackColor />
          <Blinking>False</Blinking>
          <BlinkingState>
            <BackColor />
            <ForeColor />
            <BorderColor />
            <Underline>False</Underline>
          </BlinkingState>
          <Border>
            <Width>0</Width>
            <Color />
          </Border>
          <CheckRights>False</CheckRights>
          <ClickAction>
            <ActionType>None</ActionType>
            <ChartArgs />
            <CommandArgs>
              <ShowDialog>True</ShowDialog>
              <CmdVal>0</CmdVal>
            </CommandArgs>
            <LinkArgs>
              <Url />
              <UrlParams>
                <Enabled>False</Enabled>
                <Param0 />
                <Param1 />
                <Param2 />
                <Param3 />
                <Param4 />
                <Param5 />
                <Param6 />
                <Param7 />
                <Param8 />
                <Param9 />
              </UrlParams>
              <ViewID>0</ViewID>
              <Target>Self</Target>
              <ModalWidth>Normal</ModalWidth>
              <ModalHeight>0</ModalHeight>
            </LinkArgs>
            <Script />
          </ClickAction>
          <Conditions isArray="true" />
          <CornerRadius>
            <TopLeft>0</TopLeft>
            <TopRight>0</TopRight>
            <BottomRight>0</BottomRight>
            <BottomLeft>0</BottomLeft>
          </CornerRadius>
          <CssClass />
          <DefaultText />
          <DeviceNum>1302</DeviceNum>
          <DisabledState>
            <BackColor />
            <ForeColor />
            <BorderColor />
          </DisabledState>
          <Enabled>True</Enabled>
          <Font>
            <Inherit>True</Inherit>
            <Name />
            <Size>16</Size>
            <Bold>False</Bold>
            <Italic>False</Italic>
          </Font>
          <ForeColor />
          <HoverState>
            <BackColor />
            <ForeColor />
            <BorderColor />
          </HoverState>
          <InCnlNum>131014</InCnlNum>
          <Location>
            <X>40</X>
            <Y>40</Y>
          </Location>
          <Name />
          <ObjNum>0</ObjNum>
          <OutCnlNum>0</OutCnlNum>
          <Padding>
            <Top>0</Top>
            <Right>0</Right>
            <Bottom>0</Bottom>
            <Left>0</Left>
          </Padding>
          <PropertyBindings isArray="true" />
          <Script />
          <Size>
            <Width>100</Width>
            <Height>100</Height>
          </Size>
          <Text>Text</Text>
          <TextAlign>TopLeft</TextAlign>
          <TextDirection>Horizontal</TextDirection>
          <Tooltip />
          <Visible>True</Visible>
          <WordWrap>False</WordWrap>
        </Text>
        <Face>
          <ID>2</ID>
          <ClickAction>
            <ChartArgs />
            <CommandArgs>
              <CmdVal>0</CmdVal>
            </CommandArgs>
            <LinkArgs>
              <Url />
              <UrlParams>
                <Param0 />
                <Param1 />
                <Param2 />
                <Param3 />
                <Param4 />
                <Param5 />
                <Param6 />
                <Param7 />
                <Param8 />
                <Param9 />
              </UrlParams>
              <ViewID>0</ViewID>
            </LinkArgs>
            <Script />
          </ClickAction>
          <InCnlNum>0</InCnlNum>
          <Location>
            <X>0</X>
            <Y>100</Y>
          </Location>
          <Name />
          <ObjNum>13</ObjNum>
          <Size>
            <Width>100</Width>
          </Size>
        </Face>
      </Components>
      <Images />
    </Mimic>
    Face.fp:
    <Faceplate editorVersion="6.0.2.0">
      <Dependencies />
      <Document>
        <Size>
          <Width>100</Width>
        </Size>
      </Document>
      <Components>
        <Text>
          <ID>1</ID>
          <BackColor />
          <BlinkingState>
            <BackColor />
            <ForeColor />
            <BorderColor />
          </BlinkingState>
          <Border>
            <Width>0</Width>
            <Color />
          </Border>
          <ClickAction>
            <ChartArgs />
            <CommandArgs>
              <CmdVal>0</CmdVal>
            </CommandArgs>
            <LinkArgs>
              <Url />
              <UrlParams>
                <Param0 />
                <Param1 />
                <Param2 />
                <Param3 />
                <Param4 />
                <Param5 />
                <Param6 />
                <Param7 />
                <Param8 />
                <Param9 />
              </UrlParams>
              <ViewID>0</ViewID>
            </LinkArgs>
            <Script />
          </ClickAction>
          <CornerRadius>
          </CornerRadius>
          <CssClass />
          <DefaultText />
          <DisabledState>
            <BackColor />
            <ForeColor />
            <BorderColor />
          </DisabledState>
          <Font>
            <Name />
            <Size>16</Size>
            <Bold>False</Bold>
          </Font>
          <ForeColor />
          <HoverState>
            <BackColor />
            <ForeColor />
            <BorderColor />
          </HoverState>
          <Location>
            <X>30</X>
            <Y>40</Y>
          </Location>
          <Name />
          <ObjNum>13</ObjNum>
          <Padding>
            <Top>0</Top>
            <Right>0</Right>
            <Bottom>0</Bottom>
            <Left>0</Left>
          </Padding>
          <Script />
          <Size>
            <Width>100</Width>
          </Size>
          <Text>Text</Text>
          <Tooltip />
        </Text>
      </Components>
      <Images />
    </Faceplate>
    Result:
    https://ibb.co/ptBKTd6
    https://ibb.co/Tqgs8Zzr
