Embedded mimic does not work
Forum Home › Forums › Understanding the Software › Mimics › Embedded mimic does not work
Viewing 15 posts - 16 through 30 (of 34 total)
  • #18005
    Mimics – lang RU
    You should translate this document. It is strange that there is no documentation in English in the folder.
    Test_TextFace
    An example of one of the communication options for the exported FacePlate property based on Simulator channel 103.
    #18006
    oley
    Thanks! I’ll take a look at it.
    It’ll bring back memories of my primary school days, when I was learning Russian. 🙂
    #18007
    Drop these memories and keep learning Russian 🙂
    Moreover, in Russian, something from the documentation appears faster.
    #18008
    Unfortunately, it is not a very convenient document, there is no way to copy text from a pdf and send it to an online translator. 🙁
    #18009
    oley
    What is the purpose of <DataSource>Tri</DataSource>?
    #18010
    This is the Channel 103 tag code in the Simulator
    #18013
    When a frame uses another origin (localhost:5000) than the main website (localhost:10008) is is usually blocked by a web browser according to security reasons. Try using the same host and port for frames.
    #18014
    PlgMimic Features.docx
    I think @Mikhail will not scold much, but on the contrary, he will correct that he translated the online translator incorrectly. 🙂
    #18015
    As far as I know, you just need one network, ports are not important. This is how I connected to devices with virtual network addresses, but I had to be a client of this network.
    #18019
    oley
    Thanks, I will try with the same address/url and evtl. port.
    #18020
    oley
    I would appreciate any additional guidance.
    The example with the text on a faceplate was just a simple illustration of my problem.
    My faceplates contain several images that represent the status of the switches: on, off, and undefined.
    In the faceplate, I define an input channel (and sometimes an output channel for a command), and in the conditions, I have set the appropriate images for the channel values.
        <Picture>
          <ID>3</ID>
          <BackColor />
          <Border>
            <Color>Gray</Color>
            <Width>0</Width>
          </Border>
          <ClickAction>
            <ActionType>SendCommand</ActionType>
            <CommandArgs>
              <ShowDialog>True</ShowDialog>
              <CmdVal>0</CmdVal>
            </CommandArgs>
          </ClickAction>
          <Conditions isArray="true">
            <Item>
              <ComparisonOper1>Equal</ComparisonOper1>
              <ComparisonArg1>0</ComparisonArg1>
              <LogicalOper>None</LogicalOper>
              <ComparisonOper2>LessThan</ComparisonOper2>
              <ComparisonArg2>0</ComparisonArg2>
              <ImageName>active_el04_0.png</ImageName>
            </Item>
            <Item>
              <ComparisonArg1>1</ComparisonArg1>
              <ImageName>active_el04_1.png</ImageName>
            </Item>
            <Item>
              <ComparisonArg1>2</ComparisonArg1>
              <ImageName>active_el04_2.png</ImageName>
            </Item>
            <Item>
              <ComparisonArg1>3</ComparisonArg1>
              <ImageName>active_el04_3.png</ImageName>
            </Item>
          </Conditions>
          <DefaultImage>active_el04_0.png</DefaultImage>
          <DeviceNum>4101</DeviceNum>
          <Enabled>True</Enabled>
          <Font>
            <Inherit>True</Inherit>
          </Font>
          <HoverState>
            <BackColor>Blue</BackColor>
            <ForeColor />
            <BorderColor />
            <Underline>False</Underline>
          </HoverState>
          <ImageStretch>None</ImageStretch>
          <InCnlNum>410804</InCnlNum>
          <Location>
            <X>80</X>
            <Y>80</Y>
          </Location>
          <Name>1Q1</Name>
          <ObjNum>41</ObjNum>
          <OutCnlNum>0</OutCnlNum>
          <Size>
            <Width>40</Width>
            <Height>40</Height>
          </Size>
          <Tooltip>1Q1</Tooltip>
          <Visible>True</Visible>
        </Picture>
    #18021
    If I’m not mistaken, but the conditions are not transmitted to the Image installed in faceplate.
    #18022
    If it is not related to the frame issue, please create a new topic.
    • This reply was modified 5 months, 2 weeks ago by Mikhail.
    #18026
    oley
    Hi Mikhail,
    I can, of course, create a new topic, but this topic was related to embedded faceplates in mimics diagrams and the frame issue came because it was present in my screenshots.
    The real problem now is a faceplate with multiple dynamic images embedded in a mimic diagram.
    #18027
    Are the images loaded from the external web URL? If so, it would be better to include them into the faceplate file.
