Rapid SCADA 6 Beta
Forum Home › Forums › Uncategorized Issues › Rapid SCADA 6 Beta
Viewing 15 posts - 46 through 60 (of 82 total)
  • #10999
    For the next beta update we should at least add historical and event reports. Currently the work is in progress.
    #11176
    @123abc56, deadband logic is updated and will be included in the next release.
    #11180
    kumajaya
    @Mikhail I just writing how to build SCADA 6 on VS Code in development section and I have to wait for a moderation? It wasn’t like that before.
    #11189
    If a post contains a lot of hyperlink, it can be automatically blocked by the forum protection system. Sometimes, it’s more handy to provide a one link to Google document for example.
    I found and accepted your post.
    #11250
    The scada_6.beta.10.zip update has been released. Download link in the beginning of the topic.
    What’s new:
    – Historical data and event reports
    – Fixed OPC UA client connection error
    – The configuration database has been changed
    To update the configuration database:
    1. Add the ArchiveKind table to your projects by copying it from the project template of the Administrator app.
    2. Set the type of archives in the Archives table (optional).
    3. Upload the project for execution.
    If you encounter errors related to the installation package (for example, the required dll is missing), write to this topic. Please write functionality errors in separate topics indicating version 6.
    #11251
    kumajaya
    Still working as OPC UA client and server but in log:
    Resolver could not find assembly 'Opc.Ua.Bindings.Https, Version=1.4.370.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8'
        requested by 'Opc.Ua.Core, Version=1.4.370.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8'
    Communicator seems like not handle server restart nicely:
    Data source ScadaServer: Error receiving telecontrol commands:
    Scada.ScadaException: Incorrect format of data received from the server: unable to read data packet header
       at Scada.Client.ClientBase.ReceiveResponse(DataPacket request)
       at Scada.Client.ScadaClient.GetCommand()
       at Scada.Comm.Drivers.DrvDsScadaServer.Logic.ScadaServerDSL.ReceiveCommands()
    System.IO.IOException: Unable to write data to the transport connection: Broken pipe.
     ---> System.Net.Sockets.SocketException (32): Broken pipe
       at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 count)
       --- End of inner exception stack trace ---
       at Scada.Client.ClientBase.SendRequest(DataPacket request)
    #11252
    kumajaya
    Can’t create historical data and event reports because PlgMain.Report.dll not included in ScadaWeb.
    System.IO.FileNotFoundException: Could not load file or assembly 'PlgMain.Report, Version=6.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
    • This reply was modified 4 years ago by kumajaya.
    #11254
    System.IO.FileNotFoundException: Could not load file or assembly ‘PlgMain.Report
    Fixed. scada_6.beta.10.zip was updated.
    Resolver could not find assembly ‘Opc.Ua.Bindings.Https, Version=1.4.370.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8’ requested by ‘Opc.Ua.Core
    This error message does not affect OPC UA. Discussion with OPC foundation is here.
    How to reproduce this issue?
    #11256
    kumajaya
    Yes, I confirm without https endpoints, UAExpert not list https access anymore but Opc.Ua.Bindings.Https.dll still requested.
    To confirm communicator exception, you can watch ScadaComm.log while restart Scada server.
    #11272
    While Server is restarting, connection errors in Communicator is a normal situation. Communicator reconnects when it’s possible.
    #11281
    kumajaya
    Just a little worried because no confirmation after back connected.
    I found a glitch on mobile browser in portrait mode and found it the printer icon move down because no horizontal space left.
    #11296
    It would be good to improve logging.
    Fixed. Will be included in the next release. Thank you.
    #11299
    victorlam
    May I know if the version 6 (six) will be the official release by end of the year?
    #11301
    kumajaya
    @Mikhail A good or a bad idea? https://drive.google.com/file/d/1utNnWR4-kXuTepxcD03yoQtjjSb-SbFF/preview
    – Partial PWA support
    – OS info on about page
    – User agent info on user profile
    #11306
    Yes, we plan to release it this year. The official release will be very close to the current beta version.
