Remote commumicator
Forum Home › Forums › Uncategorized Issues › Remote commumicator
Viewing 4 posts - 16 through 19 (of 19 total)
  • #13183
    DB Import Plus includes additional features described in the driver docs. I haven’t tried this module by myself.
    #13187
    Pieter
    I can not get DB Import Plus to connect to my database. I copied the files for version 5 to the scada directory. Made sure all .dll’s is unlocked. Rebooted. I could see the driver but nott use it. I added it manually. Now I can use it but its not connecting.
    The builtin DB import is giving me some trouble aswell.
    https://imgur.com/dOtITfR
    I have 2 rows of data in this example.
    However, the communicator is only giving me one row off data. see below
    https://imgur.com/SjZpYbb
    Even if I select the row count manually to 2. I get the correct row plus one empty row.
    The tags I want to get is separated like “tag1″,”tag2”
    I used a query builder to get the correct syntax. The query works 100% in sql manager query.
    This post https://forum.rapidscada.org/?topic=connect-to-microsoft-sql had the same issue but never explained how he resolved it.
    Could be advise me on how to get the 2 values I require?
    #13190
    Pieter
    DB Import Plus was the best way to go. It has an option to select column or row. When I selected row all be query tags was displayed in rows in communicator.
    #13195
    Try asking the author, @jurasskpark, on this forum or GitHub.
