Rapid SCADA 6 Beta
Forum Home › Forums › Uncategorized Issues › Rapid SCADA 6 Beta
Viewing 15 posts - 16 through 30 (of 82 total)
  • #10438
    Is there a solution to this problem on V5?
    The issue is solved in the v6.
    In the meantime, I suggest adding a column for “ratio”
    Creating a function Ratio that makes linear calculation may be more clear. For example, channel formula would be
    Ratio(0.5, 10)
    #10563
    victorlam
    May I know what is the new features for Rapid Scada 6 version here vs version 5.8.4?
    #10567
    There are a lot of changes in the kernel. Especially when working with archives. The ability to use PostgreSQL as the main database instead of the internal one. Accessing variables by tag code. Removal of restrictions on 65 thousand channels. And apparently much more… If it is possible to upgrade to version 6 or start, then it is better to do so.
    #10581
    victorlam
    Dear Sir or Madam,
    Thanks for the reply. May I know the schedule for final release? As I am new for this platform, all current settings are applied for the test points less than 5 points or channels. There’s no big impact for me on such case. But in case of error or doubt, it might not be related to the new version. Kindly advise the maturity stage of V6? Or there is no issues for me as this is a new platform to try and will migrate to this eventually.
    #10612
    The release is planned for this year.
    Choosing between version 5 and 6 depends on the requirements of the system you are working on. If you describe the requirements, I could suggest the version.
    #10778
    The scada_6.beta.9.zip update has been released. Download link at the beginning of the topic.
    Important changes:
    – Archives were improved. For Postgres archives we added the ability to write both with a period and by change, the dead zone option and the read-only mode have been added.
    Important: in an existing project, you need to check and, if necessary, correct the settings of the archives, especially the hourly ones.
    – Added InfluxDB archive.
    – Added OPC Classic driver.
    – Communicator can work as an OPC DA – OPC UA gateway.
    – The MQTT client driver can generate channels with the channel wizard.
    • This reply was modified 4 years, 1 month ago by Mikhail.
    #10789
    kumajaya
    Thanks for your beta update but somehow ScadaReport.dll not included.
    #10791
    kumajaya
    Just tested RS6 as OPC DA – OPC UA gateway, UAExpert can access it using username and password but RS6 OPC UA client driver running on Linux can’t access it with “BadIdentifyTokenInvalid” error.
    #10793
    kumajaya
    Update:
    Remove user and password from OPC UA server and connect to it anonymously works.
    #10799
    Thank you for noticing. scada_6.beta.9.zip has been fixed and reuploaded.
    Can you demonstrate a screenshot of the client settings that do not work?
    #10812
    kumajaya
    I will check.
    #10834
    Only can access OPC UA server anonymously
    The issue in DrvOpcUa has been fixed. Thank you for finding it.
    Do you prefer building the source code by yourself or should I provide an updated DLL?
    #10836
    kumajaya
    Thank you. I can rebuild it by myself.
