Daily Archive
Forum Home › Forums › Uncategorized Issues › Daily Archive
Viewing 15 posts - 16 through 30 (of 31 total)
  • #16010
    Hcinarli
    Except for the table editor, where can I do this in rapid, in the logic of the table editor or can an improvement be made in the table editor, as in the hours related to the periodic keeping of daily and monthly data?
    #16011
    Well, in the current version, probably draw your own table in a mnemonic scheme. Alternatively, you can create your own web page where you can use js to pull out the data you need and connect it as a view.
    #16012
    Hcinarli
    I thought about designing a schema for daily data, but how will I get the data I want for the channels I want?
    January 14, 00.00 Value
    January 15, 00.00 Value
    January 16, 00.00 value
    Do you have an idea that will continue or renew itself periodically?
    #16013
    If you do it in the form of a mnemonic, then you just need Calculation channels where you will copy daily data.
    But if you want flexibility, by analogy with regular tables, then you either need to refine them or make your own table plugin.
    Another way, as mentioned above, is to try a Flexible report and output it in HTML from the view.
    #16014
    Last Day report
    1
    Try to figure out the ElasticReport settings. I didn’t get what I expected from him, but in your case it might be different.
    • This reply was modified 1 year, 9 months ago by manjey73.
    #16016
    Hcinarli
    I will check for flexibility, so how should the channel properties be if I do it as a reminder, if possible, can you configure and send 1-2 channels in the project file I sent as an example?
    #16017
    unfortunately, I didn’t really figure it out myself 🙂 All the time, when I try to deal with him, I don’t have enough patience. And the primitive that I wanted to make didn’t suit me, because it doesn’t support it.
    #16021
    The screenshot on Google Drive is not public.
    #16022
    Elastic Report example is here.
    It can be displayed as a web page view.
    • This reply was modified 1 year, 9 months ago by Mikhail.
    #16024
    Hcinarli
    Sorry I updated permissions you can now access google drive.
    #16032
    There are no screenshots at the link. This conversation seems useless. I’m about to close the topic.
    #16033
    Hcinarli
    I have already shared screenshots before, I have a sample project file in driveda so that you can check the operations I have done.
    Screenshots :
    https://ibb.co/Sr49STj
    https://ibb.co/GczdZsk
    The result I get in the table view is only the current data “current” values as in the default settings, so no other values are registered.
    • This reply was modified 1 year, 9 months ago by Hcinarli.
    #16035
    Elastic_Report_Test
    Change my Elastic Report test configs there chlNum to your own and try it.
    #16037
    Hcinarli
    Can you please explain how I should test the xml files you sent, I dropped the files into the web config and wiew and uploaded them, but I don’t know how I should use them or whether I’m doing the right thing, can you explain step by step if possible?
    #16038
    Well, you need to install ElasticReport first.
    And following his example, the xml in the sent ones should be replaced with the channel numbers that you have in the project. See how it will all be displayed in html.
    I didn’t understand much, to be honest. There you can change the names of channels, what exactly to output, and so on.
