Forum Home › Forums › Installation Issues › SCADA-Web Installation › Mimic(мнемосхема)
- This topic has 37 replies, 2 voices, and was last updated 10 years, 11 months ago by
Evgen.
November 13, 2015 at 8:27 am #705
Evgen
ParticipantThere is visualization. already configured. working. but not through the web browser. and only one computer.
Visualization looks like a color change parameters when they go abroad. the movement of trolleys and their positioning and the like.
How to display a ready-made visualization through RapidSCADAТоже на русском.
Есть визуализация. уже настроена. работает. но не через браузер. а только на 1 компьютере.
Визуализация выглядит так изменение цвета параметров когда они выходят за границы. движение вагонеток и их позиционирование и тому подобное.
Как вывести уже готовую визуализацию через RapidSCADANovember 13, 2015 at 8:43 am #706
What technology is used for the visualization that is already done? Could you send a screenshot?November 13, 2015 at 9:02 am #707Evgen
Participanthttps://yadi.sk/i/vV9eUHVAkRmW9
Here screen (everything will remain, it is for the operators)
used сodesнs ops and master SCADA
change of color rendering.For perezentatsii will create another visualization
(already drawn left to wait until an engineer when to make the switch, and will pave the cable)but I just do not want to paint all over again. just a lot of areas where you have to leave as is
November 13, 2015 at 9:44 am #708
MikhailModeratorIt seems you can not do without creating a new configuration similar to the existing.
November 16, 2015 at 7:20 am #709Evgen
ParticipantHello!
I have a new question
Now screen
https://yadi.sk/i/IodXoZnzkUtL9
how to make a wider mimic?
Editor schemes stretched the full width of the work area.Здравствуйте!
У меня новый вопрос
вот скрин
как сделать мнемосхему шире?
в редакторе схем растянуто на всю ширину рабочей области.November 16, 2015 at 8:49 am #710
MikhailModeratorHi!
If you use the same monitor, check scaling in your browser.
November 16, 2015 at 10:54 am #711Evgen
ParticipantI have a question again.
How to make that sign (Figure) changes from “closed” to “closed”
under the condition x> 0 (Works) x = 0 (not working)November 16, 2015 at 10:59 am #712Evgen
How to make that sign (Figure) changes from “Works” to “not working”
IRDP condition x> 0 (Works) x = 0 (not working)
the editor of schemes, I’m interested in how to implement it!November 16, 2015 at 11:45 am #713Evgen
ParticipantThanks I figured, everything just need a close look
November 18, 2015 at 12:45 pm #723Evgen
ParticipantHello!
I am interested in the possibility of a Rapid SCADA following graphic visualizations
1 thermometer, and that the band would correspond to the real DATA
2 fan rotation when the real ventilyato work and do not rotate when the real is not working
3 pointer speedometer
and in general how to do in Rapid SCADA visualization with the movement?
Thank you in advance!P.S. If this topic already raised give the link
November 18, 2015 at 2:55 pm #726
MikhailModeratorThis is the frequent question. In the current version 4.5 you can display a gauges and meters using a set of images. Each image for the each value. Otherwise use text labels. In the spring of 2016 we are going to create a new SCADA-Web with required graphical components.
November 19, 2015 at 12:00 pm #728Evgen
ParticipantHello!
I have another question.
How to display a single chart several variables?
Here are examples of such plots.
https://yadi.sk/i/IT3dTZrikZtqk
https://yadi.sk/i/lJXuDFtvkZtriNovember 19, 2015 at 8:02 pm #732
1. The additional component ChartList
2. Component for ChartingThese components are commercial. I will send you an offer by e-mail.
November 20, 2015 at 8:38 am #735Evgen
ParticipantThank you!
If management wants will order this component.November 26, 2015 at 11:28 am #747Evgen
ParticipantЗдравствуйте!
У меня опять вопрос. Как сделать следующее, есть датчик тока(к примеру) и необходимо с точностью до секунды отслеживать его включение, выключение и токи которые выходят за нижнее и верхнее ограничения? И что бы эти данные выводились в событиях к примеру. -
