Forum Home › Forums › Development and Integration › Mobile client and Rapid SCADA
- This topic has 27 replies, 6 voices, and was last updated 6 years, 6 months ago by
April 5, 2017 at 2:29 pm #2076
SergeyLeb
ParticipantDear colleagues,
could you tell me may I realize the chem on Rapid SACADA: the Rapid SACADA is running on PC as Master RTU (or something else). The data are showed and collected on the PC and a mobile client connect to the PC via Internet for reading the information? If it possible how I can realize the process?Thank you for possible answers!
April 5, 2017 at 4:41 pm #2077
This is a one of common scenarios. Do you have detailed questions?April 5, 2017 at 5:07 pm #2078SergeyLeb
ParticipantThe main application is started on the PC. The PC works as master for Modbus network. Some time I need to connect to the application (for seeing the process status) via mobile (Android or IOS) application. So, I understand, I must to use an OPS server which delivers information for the Rapid SCADA application and something “WEB server”. Am I right?
April 6, 2017 at 12:08 pm #2079
MikhailModeratorRapid SCADA contains all the necessary features to implement this. You don’t need OPC server and other 3rd party software.
April 7, 2017 at 9:59 am #2080SergeyLeb
ParticipantSounds good! But, how I can lunch a SCADA application on a mobile device under Android? I must repeat – the main controller is running on PC. What steps I must to do for seeing the information?
April 7, 2017 at 11:27 am #2081
MikhailModeratorI mean that the web application is properly tested on iOS and Android. It is possible to create a shortcuts on mobile desktop to run the app by one click (tap). Even if web server works on Windows, the web interface is accessible via LAN or Internet using different devices.
April 7, 2017 at 11:29 am #2082
MikhailModeratorTo see the information, open up to date mobile browser and type http://your-address/scada
Find out in the Internet how to create shortcuts.April 10, 2017 at 6:13 pm #2092SergeyLeb
ParticipantThank you so much! I will try.
January 9, 2019 at 9:18 am #4826
Hennie_KotzeParticipantMikhail,
I can enter the adress of my server on another PC connected to the internet (http://xx.xx.xx.xx/scada) and it works. I can see the project running in the browser.
However,
When I enter the same adress in my android phone’s browser, it says the address cant be reached.
Is there a certain android browser version we should have?
January 9, 2019 at 9:29 am #4827
Hennie_KotzeParticipantOK,
I had my server PC and my client PC connected on the same wifi network, thats why they could connect. My Android phone was on the cellular network’s internet, and thats why it said the address cant be reached.
As soon as I connected my phone on the same wifi, I could connect to the server and view the webstation.
I’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
January 9, 2019 at 10:21 am #4829
manjey73Participant1. to do this, you must have an external static IP address for your server (router)
2. Perform the necessary router settings to access your services from outsideIf this is not possible, use third-party services such as TeamViewer and others
Remote access is already a task of IT sphere, not Scada as such.
For example I have a dedicated static IP address. I connect to my router VPN client and see the entire internal network as if I was connected inside the network via Wi-Fi and moreover, the IP address on my phones to determine the third-party services becomes the same as when connecting VPN traffic begins to pass through my home router. Sometimes it is useful for sites that require access settings from certain IP addresses and will ignore you if the addresses are carrier-based.
January 9, 2019 at 1:21 pm #4835
MikhailModeratorI’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
Is manjey73 said, VPN is the most preferable and safe way.
Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scadaDecember 25, 2019 at 8:23 am #6264hethongscada62
ParticipantDear Mr. Mikhail Shiryaev and All.
– The fist: Happy Coming New Year 2020 to you and All- .
– The second: The question about rapid Scada.
The software was installed. It is working perfectly. Was tried a Chart plugin. It was Great. Can access a web remotely via internet. Great more. It was made me excited. But the remote communication i can not get. Could you help me to find where is my wrong ? One Desktop PC was installed rapid scada (full Apps) as server, Can see web via No-IP domain.ddns.net/scada. Another PC was installed only Communication App of rapid and connected with Modbus device (electricity meter) via WiFi of local network that was connecting to internet. Can not connect to scada server.
Hope get the answer from You and All soon.
Thanks and best regardsDecember 25, 2019 at 1:59 pm #6272
MikhailModeratorThe possible cause is the settings of network equipment.
If Communicator works in the same LAN as SCADA-Server, I strongly suggest to specify Server IP address instead of DNS name. The important thing is that SCADA-Server opens TCP port 10000 for connection. It must be enabled on advanced settings of Windows firewall. In case you use DNS, it also must be allowed in the router settings.Have you checked the firewall and network equipment?
May 8, 2020 at 8:41 am #6813arvxn01
ParticipantGood morning,
I have the same problem as Hennie Kotze. I am student and i’m working on my project.
I have my server PC and my iPhone is used as client device. I can connect to the webstation if the server and the iPhone are connected to the same Wifi network.
But if my iPhone use cellular network, it said the adress cant be reached.I don’t need specifically an external static IP adress. I will check each time the IP adress before access it.
But @manjey73 said : “2. Perform the necessary router settings to access your services from outside”.
Can you tell me what is the necessary settings I need to perform on my router ? -
