Export to Database Module
Forum Home › Forums › Development and Integration › Export to Database Module
Viewing 15 posts - 1 through 15 (of 25 total)
  • #3981
    t_bidaud
    I work on Arduino module and I would like to export the Cnlnum ; Stat & Val on a database.
    I would like to connect the current.dat to my oracle database with the Export database Module.
    I try to connect with Modules_ModBDExport.dll. But I don’t understand where I use the connection string and when I use the sql queries.
    Thank you for your help.
    Theofane Bidaud
    #3982
    You should create a new database connection in the module properties form and paste SQL requests for this connection.
    What is the particular question?
    #3983
    t_bidaud
    I don’t understand where I connect the database in SCADA Serveur _ Modules _ ModBDExport.dll _ Connection.
    And when I write the SQL code in documentation.
    #3992
    1. Go to the Modules page
    2. Click the Add (+) button
    3. Add ModDBExport.dll and apply the settings.
    4. Select the module and click the Properties button.
    #3995
    t_bidaud
    I chose Oracle in Add data source
    In connection I have :
    Serveur localhost
    Database test_bdd.sql
    User t_bidaud
    BDD123
    Connexion String
    Server=localhost/test_bdd.sql;UserID=t_bidaud;Password=BDD123
    And in Current Data I check Export and I put in SQL window the SQL code in documentation.
    But I have any new line in my Oracle database after.
    #3997
    You should provide screenshots of the module settings and log of the export module.
    #4002
    t_bidaud
    I send you an email with screenshots
    #4003
    t_bidaud
    This is the screenshot:
    #4004
    In the Current Data tab you need to enter INSERT request only. Other SQL scripts are needed for creating the database.
    #4031
    t_bidaud
    Ok i did it, I put the insert command in current, archive & event.
    I create a data base with the other command.
    But when I try SELECT * FROM clndata; I have nothing.
    I forced to use mysql.
    Thank you for your helping
    #4039
    You should check the log file of the module to find the cause.
    MySQL is owned by Oracle Corporation ))
    #4043
    t_bidaud
    I able to tranfert data with the generator.
    But I can’t sent automatically data from server
    #4044
    You should describe in details what you did, what you get and what you expect.
    #4045
    t_bidaud
    I have configured the connection with my data base
    I want to upload in my data base the current dta from the scada server.
    When I use the generator I recieve just one data
    I want to recieve data/min.
    #4054
    Thank you for the screenshots.
    Do the data are successfully stored in your database when you use Generator?
