Forum Home › Forums › Development and Integration › Building the app error
- This topic has 17 replies, 3 voices, and was last updated 6 years, 10 months ago by
December 23, 2019 at 1:39 pm #6241
hicode
ParticipantHello !
First : thanks for your work !
Second : i have a problem, i was building the app, until the OpenPlugins block me …
When i build, my IDE say’s : ” ‘WebUtils’ ne contient pas de définition pour ‘QueryParamToIntArray’ ” (its in french but it say that WebUtils don’t have a method named QueryParamToIntArray).Thanks for your help
December 23, 2019 at 1:56 pm #6244
You should get the source code from the master branch v5.7.1
In this case, I hope, the projects will be consistent. And you get the same binaries that are included in the installation package.it say that WebUtils don’t have a method named QueryParamToIntArray
This method was deleted recently.
December 23, 2019 at 2:06 pm #6245hicode
ParticipantThanks for quick reply,
Oh ok, i taked to code source from github, but i will try with your link !December 23, 2019 at 3:24 pm #6246hicode
ParticipantIt work’s better thanks !
Or almost, i try to use the ServerAdmin5, because the classic ServerAdmin need DataBase in a special format.
But when i try to build ScadaAdmin5 i need the ScadaWebCommon5 Assembly but i only have the classic ScadaWebCommon..December 24, 2019 at 3:02 pm #6256
MikhailModeratori taked to code source from github, but i will try with your link !
My link is also GitHub.
That’s correct.
Current name is ScadaWebCommon. The issue is strange. Could you make a screenshot of Visual Studio solution explorer with expanded References node?
December 25, 2019 at 6:54 am #6263Dmitriy
ParticipantHello,
I have problem with OpenKPs project. I tried v5.7.1, but got same building errors.
Error log hereDecember 25, 2019 at 1:54 pm #6270
The problems are in KpSnmp.dll. If you don’t need it, just unload KpSnmp project. If you need, check where it looks for SharpSnmpLibDecember 25, 2019 at 1:56 pm #6271
MikhailModeratorProbably, you got problems with NuGet references. Open NuGet manager and check.
KpSnmp and KpOpcUa uses NuGet packages.December 26, 2019 at 6:35 am #6274Dmitriy
ParticipantThanks!
I restored NuGet packages for KpSnmp and it works.
But I still got errors with KpOpcUa, it could not resolve assemblies “Log”, “ScadaCommCommon and “ScadaData”.
Error logDecember 26, 2019 at 12:26 pm #6276
MikhailModeratorLog, ScadaCommCommon and ScadaData are located in the same repository. Build them before. Don’t forget to switch from Debug to Release configuration when build.
December 27, 2019 at 7:35 am #6277Dmitriy
ParticipantI built sources according to the instructions from “HowToBuild” file. I already built all solutions before KpOpcUa in Release configuration, but KpOpcUa could not resolve assemblies. I alse tried to build a sources on another computer, but got the same building errors.
December 27, 2019 at 1:37 pm #6278
MikhailModeratorYou should check the dependencies. There are no magic.
January 2, 2020 at 7:57 am #6298hicode
ParticipantI put the screen here : https://ibb.co/SVRLzXN
thanksJanuary 2, 2020 at 7:59 am #6299hicode
Participantalso this screen : https://ibb.co/njVq4nL
January 3, 2020 at 7:20 am #6306
MikhailModeratorTry removing ScadaWebCommon5 dependency. Does it help?
