Source Code KpOpc.dll
Forum Home › Forums › Development and Integration › Source Code KpOpc.dll
Viewing 9 posts - 46 through 54 (of 54 total)
  • #3622
    syndrome5
    Thank you for this update.
    I’m currently working on Alarms with OPC UA. I see that under the scheme there is an eventbox. What’s the process to add a line (here an alarm, and if possible with acknowledgment system) with name, reason etc ?
    #3623
    The example of creating events starts here.
    #3624
    This code helps to understand how event text is built.
    #4728
    SuperDev
    Hi Mikhail
    Would you please give me alink to OPC DA source?
    Thanks alot
    #4729
    SuperDev
    Thanks a million
    #18293
    Rohan Udith
    Hi Mikhail,
    I am looking to access the source code for KpOpc.dll (OPC driver). However, I am unable to locate it within the main Rapid SCADA source code repository.
    Could you please provide a working download link or point me to where the source files for this driver are hosted?
    Thank you!
    #18295
    Link
    #18297
    Rohan Udith
    Thanks alot
