Forum Home › Forums › Development and Integration › XML Content Translator for SCADA 6
- This topic has 25 replies, 5 voices, and was last updated 8 months ago by
JurasskPark.
October 24, 2022 at 10:13 am #11368
MikhailModeratorI’m doing a content translation for Chinese Simplified, thank you
It it very useful. Please make a pull request when ready.
April 11, 2025 at 2:25 am #16339JW
ParticipantI updated the Chinese Simplified language pack, include all default SCADA applications and auto control module and chart pro. Credit to geffzhang for the previous translation.
https://1drv.ms/u/c/7d196e63b671ad1b/EQpixQ8Wvs5CoQBQX3FAW04BdlybwnHzbnhuXZLwgLZ5DQ?e=U3ZDCS
Also I found that the text of Project properties popup windows does not exist in the xml files, even the original en-GB xml files.
https://1drv.ms/i/c/7d196e63b671ad1b/EfqYJYdqwJ9DieFuwXUPWrMByF8pr6DgQcqh3harDAyfnA?e=LbfKSK
April 11, 2025 at 2:58 pm #16342
I have downloaded the translation and I will try to merge it. It may take some time.Also I found that the text of Project properties popup windows does not exist in the xml files
Indeed, this needs to be fixed.
April 22, 2025 at 7:34 am #16357
I noticed that the culture name of the translation was changed fromzh-Hanstozh-Hans-CN. The second is a region-specified culture.
Could you please clarify what the difference is from a user experience perspective?
What caused the change?-
This reply was modified 1 year, 7 months ago by
April 23, 2025 at 6:30 am #16364JW
ParticipantIn the Administrator – Webstation – culture name options, the selection only has zh-Hans-CN and zh-Hans-HK/MO/SG, but not zh-Hans. So, I changed it for easy use. since mostly CN region uses simplified-Chinese, while other regions mostly use traditional-Chinese.
If zh-Hans can be added to Administrator App, it would be better to use zh-Hans.
April 23, 2025 at 11:07 am #16366
MikhailModeratorThis line of code filters the culture list. May be all cultures should be added to the list without any filtering.
April 23, 2025 at 11:19 am #16367
MikhailModeratorIn the next release
zh-Hanswill be added to the drop-down list. Do you have a script to rename all the files in the translation back to *.zh-Hans.xml?April 25, 2025 at 10:24 am #16370JW
Participantthe file in the following link (same as previous link) is update to *.zh-Hans.xml
April 25, 2025 at 10:50 am #16372
MikhailModeratorThank you!
I will try to merge it, and write here when completed.April 28, 2025 at 12:02 pm #16380
MikhailModeratorMerged to https://rapidscada.org/download/lang_pack/lang_pack_2.2.zip
Thank you.March 23, 2026 at 12:43 pm #17778
JurasskParkParticipantPosted an updated version of the app:
– Translated from Net Framework 4.8 to Net Core 8.0.
– Added support for the Yandex.Translate service.
– Automatic extraction of translation strings from the application’s design forms.
– Code generation from the names of the ListView and DataGridView columns.
– I’ve put the code in order.
– I cut out the functionality that I considered superfluous.Project website https://github.com/JurasskPark/Xml sitemap generator
The app https://github.com/JurasskPark/XmlContentTranslator/releases -
