Forum Home › Forums › Development and Integration › Several days/channels graphs are generated slooooowly
- This topic has 21 replies, 2 voices, and was last updated 10 years, 6 months ago by
May 24, 2016 at 4:30 pm #1245
inpelsaParticipantMy 2 cents to speed you up:
What makes it slow is not graph drawing: is javascript populating HTML-Table data for the 2nd and following days.
Example: graph 30 days 10 channels takes 1:30 on my computer
– Querying each data day takes 0.5 seconds: 1 data query of 30 days will save ~15 seconds, but as this will send data table already created it will show inmediatelly at server’s costs.
If sending full graph data is too complex I see those improvements:
On DIAG.JS, function AppendDiagDataTable(diagData) :
var rows = table.children(":first").children("tr"); // tbody, tr if (rows.length == diagData.DiagCnt + 1) { var rowTime = rows.eq(0); // время var buffertest =""; console.log(GetNowDT() + " mark loop 1 IN " + diagData.PtCnt); for (var j = 0; j < diagData.PtCnt; j++) { buffertest=buffertest + $("<td>").text(Diag.TimeToStr(diagData.DiagTimeArr[j], TableTimeOptions)); } console.log(GetNowDT() + " mark loop 1 OUT " ); rowTime.append(buffertest); console.log(GetNowDT() + " mark loop 1 after append "); buffertest =""; console.log(GetNowDT() + " mark loop 2 IN " + diagData.DiagCnt); for (var i = 0; i < diagData.DiagCnt; i++) { var rowVal = rows.eq(i + 1); // значения var trend = diagData.DiagDataArr[i].TrendDataArr; for (var j = 0; j < diagData.PtCnt; j++) { var dataItem = trend[j]; buffertest=buffertest + $("<td>") .css("color", dataItem[Diag.ColorInd]) .append($("<div>").text(dataItem[Diag.DisplayValInd])); } } console.log(GetNowDT() + " mark loop 2 OUT " ); rowVal.append(buffertest); console.log(GetNowDT() + " mark loop 2 after append "); buffertest =""; }– If you use a buffer instead of .append each loop you save ~15 seconds
– Loop 1 takes about 15 seconds (adds time data?)
– Loop 2 takes about 45 seconds (sets value data and color to text data when you scroll over graph?)I will try to remove Loop 2 to be able to work.
Maybe creating data table in a different way/technology or optimizing functions used inside loops will improve it enough.
Bye!
May 24, 2016 at 5:16 pm #1246
inpelsaParticipantWell, I didn’t
seeunderstood it before…AppendDiagData(diagData); AppendDiagDataTable(diagData);That second whole function is just to show the data table when you press the “show data” button.
I don’t usually need it, I will comment that function. Now it takes just 20 seconds instead of 1:30.
Anyway, implementing those improvements will make it much faster 🙂
May 25, 2016 at 10:35 am #1248
MikhailModeratorThanks!
If somebody are able to compare the charting speed with other SCADA software, it would be very interesting and useful.
May 25, 2016 at 10:54 am #1250
inpelsaParticipantSure, here you have:
It’s and old SCADA system called Freelance (1990) we use here.
It generates all graphs instantly (5 channels, 3 weeks of data, samples every 5 seconds) but most probably it will use some kind of grouping when zooming out.I will take a look to the Schneider Electric IGSS demo but not sure it keeps data for so long time.
May 25, 2016 at 4:03 pm #1251
MikhailModeratorProbably it keeps all the data in a cache.
Are the client and the server on the one PC?May 25, 2016 at 4:14 pm #1252
inpelsaParticipantYes, but even without cache and that amount of data… it can be plotted quite fast.
The problem is AppendDiagDataTable(diagData) (does somebody use it?) and receiving data day per day: after removing that function everything works much better.
just try it, send 30 days data to the graph and you will see it plotted in a second as it does when de-zooming.
May 26, 2016 at 7:15 am #1254
MikhailModeratorWhen I start a work of porting the chart component to the new web app, I will do an optimization. Thank you for the useful information, you saved my time.
