Export to Database Module
Forum Home › Forums › Development and Integration › Export to Database Module
Viewing 10 posts - 16 through 25 (of 25 total)
  • #5622
    fhserver
    hi,
    Can you tell me, the correct way to configure the database.
    “Configure connection” Is this configuration referring to the database of rapid scada? If so, what are the default credentials?
    imagen1
    Config server Mysql
    imagen2
    Query Sql
    imagen3
    Tables DB
    imagen4
    I can not copy the data, to the external DB Mysql.
    #5627
    Connection settings on the 1st image are not related to database. Don’t mind about them.
    You should find ModDBExport.log and ModDBExport.txt in C:\SCADA\ScadaServer\Log and check the error details.
    #5631
    fhserver
    Apparently I have problems with the MYSQL database.
    imagen5
    Thank you very much for the help !!
    I’ll tell you as soon as I solve it
    #5640
    May be you should change cnlmun to cnlnum in the INSERT request.
    #5643
    fhserver
    Thank you ! , layer 8 error (between the chair and the keyboard).
    Captura02xº
    Log.
    Captura03
    #5648
    Is the “duplicate entry” error critical in your situation or can be ignored?
    #5706
    fhserver
    Disable PK, I have not had any more problems
    tablas<br />
    Log.
    log<br />
    • This reply was modified 7 years, 4 months ago by fhserver.
    #5714
    This is a bad practice, because records still duplicated, but without error.
    Somewhere in this forum or https://forum.rapidscada.ru/, a solution how to skip inserting duplicated records.
    #5716
    fhserver
    Apparently this was solved
    SQL
    https://i.ibb.co/6ypdsjG/sql.png
    Table
    https://i.ibb.co/YdqGZ9V/key.png
    Log
    https://i.ibb.co/bJRnYzY/log.png
    • This reply was modified 7 years, 4 months ago by Mikhail.
    #5727
    On my PC images are not available. Could you check them?
