Database SQL usage
Forum Home › Forums › Development and Integration › Database SQL usage
Viewing 4 posts - 16 through 19 (of 19 total)
  • #9150
    May be the new DB export module can help you. But I’m not sure that it’s compatible with your version of Rapid SCADA. And there is no manual for the module. Anyway, let’s try.
    #9321
    Han
    Hi, I have been busy with other things recently. Which version of Rapid SCADA is needed?
    #9325
    5.8.3
    I think, 5.8.2. If needed, it the module can be updated to be compatible with 5.8.3.
    • This reply was modified 5 years, 3 months ago by Mikhail.
    #9424
    Nguyen
    Hi. Did you solve your problem? I have got the same problem with you.
