KPOpcUa.dll – Linux with Mono Error
Forum Home › Forums › Communicating with Devices › KPOpcUa.dll – Linux with Mono Error
Viewing 15 posts - 1 through 15 (of 16 total)
  • #6730
    chrisn
    Hi Everyone,
    We are doing a deploy which includes a Linux server (CentOS 8) running Mono and utilising OPC UA for connection to our PLCs. The configuration works perfectly on our Windows environment, but on shifting to the Linux config the OPC connections just seem to timeout and error. There is no error in the ScadaComm log other than the KPOPC.DLL having an issue with a dependancy which I believe would be expected as I believe this is for OPC DA. The KP OPC UA DLL loads without error.
    Has anyone experience with OPC UA under Linux?
    #6737
    We tested KpOpcUa.dll driver on Debian family. Could you copy a particular error message or provide screenshots?
    #6994
    kumajaya
    Error on Ubuntu 20.04:
    2020-07-09 14:44:00 Communication session with the Device 1002 “OPC UA 02”, type: KpOpcUa
    Error connecting OPC server: System.AggregateException: One or more errors occurred. (Cannot access certificate private key. Subject=CN=KpOpcUa, O=OPC Foundation, DC=weighing-tx1310-m3) —> Opc.Ua.ServiceResultException: Cannot access certificate private key. Subject=CN=KpOpcUa, O=OPC Foundation, DC=weighing-tx1310-m3
    at Opc.Ua.Configuration.ApplicationInstance.CheckApplicationInstanceCertificate (System.Boolean silent, System.UInt16 minimumKeySize, System.UInt16 lifeTimeInMonths) [0x0028d] in <257f0400988e4a10b271f6f92984b904>:0
    at Scada.Comm.Devices.OpcUa.OpcUaHelper.ConnectAsync (Scada.Comm.Devices.OpcUa.Config.ConnectionOptions connectionOptions, System.Int32 operationTimeout) [0x00138] in <39294643693b45b3b8e6300c5758da94>:0
    at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) [0x00011] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at System.Threading.Tasks.Task`
    1[TResult].GetResultCore (System.Boolean waitCompletionNotification) [0x0002b] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at System.Threading.Tasks.Task`1[TResult].get_Result () [0x0000f] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at Scada.Comm.Devices.KpOpcUaLogic.ConnectToOpcServer () [0x00051] in <39294643693b45b3b8e6300c5758da94>:0
    —> (Inner Exception #0) Opc.Ua.ServiceResultException: Cannot access certificate private key. Subject=CN=KpOpcUa, O=OPC Foundation, DC=weighing-tx1310-m3
    at Scada.Comm.Devices.OpcUa.OpcUaHelper.ConnectAsync (Scada.Comm.Devices.OpcUa.Config.ConnectionOptions connectionOptions, System.Int32 operationTimeout) [0x00138] in <39294643693b45b3b8e6300c5758da94>:0 <—
    • This reply was modified 6 years, 4 months ago by kumajaya.
    #6996
    kumajaya
    Copy KpOpcUa.Linux.xml as KpOpcUa.Logic.xml but replace all ‘%LocalApplicationData%’ string with ‘%CommonApplicationData%’ solve above problem but now I got:
    Error connecting OPC server: System.AggregateException: One or more errors occurred. (The type initializer for ‘Opc.Ua.ServiceMessageContext’ threw an exception.) —> System.TypeInitializationException: The type initializer for ‘Opc.Ua.ServiceMessageContext’ threw an exception. —> System.TypeInitializationException: The type initializer for ‘Opc.Ua.EncodeableFactory’ threw an exception. —> System.TypeLoadException: Could not load type of field ‘Opc.Ua.JsonDecoder:m_reader’ (0) due to: Could not load file or assembly ‘Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed’ or one of its dependencies.
    at (wrapper managed-to-native) System.RuntimeTypeHandle.type_is_assignable_from(System.Type,System.Type)
    at System.RuntimeTypeHandle.CanCastTo (System.RuntimeType type, System.RuntimeType target) [0x00000] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at System.RuntimeType.IsAssignableFrom (System.Type c) [0x00020] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at System.RuntimeType.IsAssignableFrom (System.Reflection.TypeInfo typeInfo) [0x00012] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    at Opc.Ua.EncodeableFactory.AddEncodeableType (System.Type systemType) [0x00034] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.EncodeableFactory.AddEncodeableTypes (System.Reflection.Assembly assembly) [0x00034] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.EncodeableFactory..ctor () [0x0002d] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.EncodeableFactory..cctor () [0x00000] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.ServiceMessageContext..ctor () [0x00053] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.ServiceMessageContext..ctor (System.Boolean shared) [0x00000] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.ServiceMessageContext..cctor () [0x00000] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.DiscoveryClient.Create (System.Uri discoveryUrl, Opc.Ua.EndpointConfiguration configuration) [0x0000a] in <46754062c86e433a8050147004074236>:0
    at Opc.Ua.Client.CoreClientUtils.SelectEndpoint (System.String discoveryUrl, System.Boolean useSecurity, System.Int32 operationTimeout) [0x00041] in <bdddc5532da84081a96bd9e7feb3ef1e>:0
    at Scada.Comm.Devices.OpcUa.OpcUaHelper.ConnectAsync (Scada.Comm.Devices.OpcUa.Config.ConnectionOptions connectionOptions, System.Int32 operationTimeout) [0x001e9] in <39294643693b45b3b8e6300c5758da94>:0
    at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) [0x0002b] in <a17fa1457c5d44f2885ac746c1764ea5>:0
    —> (Inner Exception #0) System.TypeInitializationException: The type initializer for ‘Opc.Ua.ServiceMessageContext’ threw an exception. —> System.TypeInitializationException: The type initializer for ‘Opc.Ua.EncodeableFactory’ threw an exception. —> System.TypeLoadException: Could not load type of field ‘Opc.Ua.JsonDecoder:m_reader’ (0) due to: Could not load file or assembly ‘Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed’ or one of its dependencies.
    at Scada.Comm.Devices.OpcUa.OpcUaHelper.ConnectAsync (Scada.Comm.Devices.OpcUa.Config.ConnectionOptions connectionOptions, System.Int32 operationTimeout) [0x001e9] in <39294643693b45b3b8e6300c5758da94>:0 <—
    #6997
    Try this file.
    You should create directories:
    /opt/scada/OPC Foundation/pki/app
    /opt/scada/OPC Foundation/pki/issuer
    /opt/scada/OPC Foundation/pki/trusted
    /opt/scada/OPC Foundation/pki/rejected
    /opt/scada/OPC Foundation/pki/issuerUser
    /opt/scada/OPC Foundation/pki/trustedUser
    and provide write access for them.
    #6998
    What is Mono version?
    #6999
    kumajaya
    I managed to fix self signed certificate generation by changing ‘%LocalApplicationData%’ to ‘%CommonApplicationData%’. Certificate saved inside ‘/usr/share/OPC Foundation/’.
    #7000
    kumajaya
    kumajaya
    But OPCUA still doesn’t work with “Could not load file or assembly ‘Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed’ or one of its dependencies” error.
    #7004
    Try downloading Newtonsoft.Json from NuGet and copy to /opt/scada/ScadaComm/KP
    You need Newtonsoft.Json version >= 10.0.3
    Does it help?
    Probably Mono on my Linux computer already contains it somehow.
    #7005
    OPC UA dlls depend on Newtonsoft.Json. See this for the details.
    #7006
    kumajaya
    Official release have a lot of target framework inside https://github.com/JamesNK/Newtonsoft.Json/releases Which one should I choose?
    #7007
    kumajaya
    Now I got “Could not load file or assembly ‘Microsoft.AspNetCore.Hosting.Abstractions, Version=1.1.3.0, Culture=neutral, PublicKeyToken=adb9793829ddae60’ or one of its dependencies.” Installing https://docs.microsoft.com/en-us/dotnet/core/install/linux-ubuntu still not solve the problem, maybe because older OPCUA library expect older version .NET core
    #7009
    kumajaya
    Newtonsoft.Json.dll release 10.0.3 for net45 target from https://github.com/JamesNK/Newtonsoft.Json/releases/download/10.0.3/Json100r3.zip and Microsoft.AspNetCore.Hosting.Abstractions.dll from dotnet-sdk-2.1 https://docs.microsoft.com/en-us/dotnet/core/install/linux-ubuntu#scripted-install fix the problem. Big thanks!
    #7012
    kumajaya
