new csv file reder driver
Forum Home › Forums › Communicating with Devices › new csv file reder driver
Viewing 15 posts - 16 through 30 (of 33 total)
  • #14853
    sperate
    Also you can delete the existing file and create a new one. It should work.
    Ok, maybe I’ll give it a try
    This is possible to make a time difference as a parameter. I’ve made a note in the back log. If you need it in time, we can do that on paid basis.
    Not in a hurry but it could be an interesting option anyway. Even an “unlimited time” difference coulb be possible as you already have the position counter and , as far as I understand, the driver only reads data that’s after the position counter. Wich means only new data, regardless of the time.
    And about demo mode ? What’s the trick to make the driver read data ?
    Many thanks !
    • This reply was modified 2 years, 4 months ago by sperate.
    #14869
    It is useful to simulate a device with your data.
    #14888
    sperate
    I mean I can’t make it work.
    I was asking if there’s something I’m missing to make it work.
    I can’t find what is wrong in my .csv file.
    The same way as for the real time mode, what does the driver expect in order to to consider data valid and update the Tag values ?
    You said earlier that for axample for the hour period the full hour data must be filled. Ok, I’ve tried with one minute data but nothing was read nor displayed on the communicator. Is there a specific time “step” to use between recordings ?
    #14893
    Could you make a screenshot of your CSV for demo mode?
    #14913
    sperate
    Here’s the content of the csv file
    Timestamp,TagTest
    2024-07-07 13:00:00,2000
    2024-07-07 13:01:00,2000
    2024-07-07 13:02:00,2000
    2024-07-07 13:03:00,2000
    2024-07-07 13:04:00,2000
    2024-07-07 13:05:00,2000
    2024-07-07 13:06:00,2000
    2024-07-07 13:07:00,2000
    2024-07-07 13:08:00,2000
    2024-07-07 13:09:00,2000
    2024-07-07 13:10:00,2000
    2024-07-07 13:11:00,2000
    2024-07-07 13:12:00,2000
    2024-07-07 13:13:00,2000
    2024-07-07 13:14:00,2000
    2024-07-07 13:15:00,2000
    2024-07-07 13:16:00,2000
    2024-07-07 13:17:00,2000
    2024-07-07 13:18:00,2000
    2024-07-07 13:19:00,2000
    2024-07-07 13:20:00,2000
    2024-07-07 13:21:00,2000
    2024-07-07 13:22:00,2000
    2024-07-07 13:23:00,2000
    2024-07-07 13:24:00,2000
    2024-07-07 13:25:00,2000
    2024-07-07 13:26:00,2000
    2024-07-07 13:27:00,2000
    2024-07-07 13:28:00,2000
    2024-07-07 13:29:00,2000
    2024-07-07 13:30:00,2000
    2024-07-07 13:31:00,2000
    2024-07-07 13:32:00,2000
    2024-07-07 13:33:00,2000
    2024-07-07 13:34:00,2000
    2024-07-07 13:35:00,2000
    2024-07-07 13:36:00,2000
    2024-07-07 13:37:00,2000
    2024-07-07 13:38:00,2000
    2024-07-07 13:39:00,2000
    2024-07-07 13:40:00,2000
    2024-07-07 13:41:00,2000
    2024-07-07 13:42:00,2000
    2024-07-07 13:43:00,2000
    2024-07-07 13:44:00,2000
    2024-07-07 13:45:00,2000
    2024-07-07 13:46:00,2000
    2024-07-07 13:47:00,2000
    2024-07-07 13:48:00,2000
    2024-07-07 13:49:00,2000
    2024-07-07 13:50:00,2000
    2024-07-07 13:51:00,2000
    2024-07-07 13:52:00,2000
    2024-07-07 13:53:00,2000
    2024-07-07 13:54:00,2000
    2024-07-07 13:55:00,2000
    2024-07-07 13:56:00,2000
    2024-07-07 13:57:00,2000
    2024-07-07 13:58:00,2000
    2024-07-07 13:59:00,2000
    Screen captures are here : https://imgur.com/a/nXhc4Dd
    Thanks !
    #14914
    If DemoPeriod=OneHour, the 1st timestamp must be 2024-07-07 0:00:00 and the last 2024-07-07 0:59:00
    #14915
    sperate
    I tried with this file but it didn’t work.
    Nothing read by the driver except the tag name .
    Timestamp,Astro
    2024-07-09 00:00:00,33
    2024-07-09 00:01:00,33
    2024-07-09 00:02:00,33
    2024-07-09 00:03:00,33
    2024-07-09 00:04:00,33
    2024-07-09 00:05:00,33
    2024-07-09 00:06:00,33
    2024-07-09 00:07:00,33
    2024-07-09 00:08:00,33
    2024-07-09 00:09:00,33
    2024-07-09 00:10:00,33
    2024-07-09 00:11:00,33
    2024-07-09 00:12:00,33
    2024-07-09 00:13:00,33
    2024-07-09 00:14:00,33
    2024-07-09 00:15:00,33
    2024-07-09 00:16:00,33
    2024-07-09 00:17:00,33
    2024-07-09 00:18:00,33
    2024-07-09 00:19:00,33
    2024-07-09 00:20:00,33
    2024-07-09 00:21:00,33
    2024-07-09 00:22:00,33
    2024-07-09 00:23:00,33
    2024-07-09 00:24:00,33
    2024-07-09 00:25:00,33
    2024-07-09 00:26:00,33
    2024-07-09 00:27:00,33
    2024-07-09 00:28:00,33
    2024-07-09 00:29:00,33
    2024-07-09 00:30:00,33
    2024-07-09 00:31:00,33
    2024-07-09 00:32:00,33
    2024-07-09 00:33:00,33
    2024-07-09 00:34:00,33
    2024-07-09 00:35:00,33
    2024-07-09 00:36:00,33
    2024-07-09 00:37:00,33
    2024-07-09 00:38:00,33
    2024-07-09 00:39:00,33
    2024-07-09 00:40:00,33
    2024-07-09 00:41:00,33
    2024-07-09 00:42:00,33
    2024-07-09 00:43:00,33
    2024-07-09 00:44:00,33
    2024-07-09 00:45:00,33
    2024-07-09 00:46:00,33
    2024-07-09 00:47:00,33
    2024-07-09 00:48:00,33
    2024-07-09 00:49:00,33
    2024-07-09 00:50:00,33
    2024-07-09 00:51:00,33
    2024-07-09 00:52:00,33
    2024-07-09 00:53:00,33
    2024-07-09 00:54:00,33
    2024-07-09 00:55:00,33
    2024-07-09 00:56:00,33
    2024-07-09 00:57:00,33
    2024-07-09 00:58:00,33
    2024-07-09 00:59:00,33
    #14916
    1. Set FileName=Astro2.csv
    2. Locate the file in SCADA\ScadaComm\Storage
    3. Set date to 2001-01-01 instead of 2024-07-09
    #14926
    sperate
    Hi Mikhail,
    It’s working with the date set to 2001.1.1.
    No need to change the file location (Tag name was already read).
    Just the driver didn’t like the timestamps.
    That’s what is reading now :
    [4] Ephemerides Soleil 2
    Driver       : DrvCsvReader 6.0.0.0
    Status       : Normal
    Session time : 15/07/2024 09:34:10
    Command time : Undefined
    Sessions (total / errors) : 4 / 0
    Commands (total / errors) : 0 / 0
    Requests (total / errors) : 4 / 0
    Current Data
    | # | Code      | Name      |               Value | Channel |
    | *********************** Main Data *********************** |
    | 1 | Tag1      | Astro     |              60.000 |         |
    | ******************** Reading Status ********************* |
    | 2 | Timestamp | Timestamp | 1/1/2001 1:35:00 AM |         |
    | 3 | Position  | Position  |               1,024 |         |
    I clearly don’t understant what’s the trick with the timestamps because the hours doesn’t correspond to anything (minutes arse sync. though) but it’s working right now, so i’m happy with that 🙂
    #14934
    I checked, 2001-01-01 is a starting point in demo mode, specified in the source code.
    #14978
    sperate
    Ok, thanks !
    #15585
    ScJib
    Apologies for jumping on an old thread but is there a possibility of having this functionality to ‘ignore timestamp’..?
    “Not in a hurry but it could be an interesting option anyway. Even an “unlimited time” difference coulb be possible as you already have the position counter and , as far as I understand, the driver only reads data that’s after the position counter. Wich means only new data, regardless of the time.”
    #15586
    That issue has been added to the backlog. If it is needed by a certain time, we could implement it for some fee. Otherwise, we will do it ourselves, but it is not known by what date.
    #16179
    quintelosky
    Hi
    I don’t know the problem:
    https://ibb.co/qFdQXGYz
    #16183
    quintelosky
    Ok, solved, in real time you need add a new line in your .csv
    Now I’m testing demo mode but nothing
