Connect two pc with RapidGate
Forum Home › Forums › Communicating with Devices › Connect two pc with RapidGate
Viewing 4 posts - 16 through 19 (of 19 total)
  • #12883
    manyan2028
    hello Mikhail
    I donot know how to config the Option to achieve data transfer between rapidSCADAs。 In connection Option host is the remote PC IP,username admin password scada 。 port and the TimeOUt is the default。 the instance and the Secret Key is null . uopload the Project to the PC .BUt I cannot rececive the Current Data in the Remote PC。can you help me to finish the test environment.
    #12884
    manyan2028
    Hello,Mikhail,my log output as follow:(the connection option password is scada,not the sacada)
    Gateway State
    Name : [1] [GateName]
    Server : 10.1.20.188
    Connection : Error
    Current Data
    Status : Error
    In queue : 13 of 1000
    Exported : 0
    Skipped : 0
    Historical Data
    Status : Normal
    In queue : 0 of 1000
    Exported : 0
    Skipped : 0
    Events
    Status : Error
    In queue : 127 of 1000
    Exported : 0
    Skipped : 0
    Event Acknowledgements
    Status : Normal
    Exported : 0
    Skipped : 0
    Incoming Commands
    Status : Enabled
    Received : 0
    Outcoming Commands
    Status : Normal
    Exported : 0
    Skipped : 0
    Archive Replication
    Is ready : Yes
    Tasks in queue : 0 of 10
    Task : None
    #12885
    manyan2028
    2023-06-28 13:54:46 Error transferring current data:
    Scada.Protocol.ProtocolException: Server and client secret keys do not match.
    at Scada.Client.ClientBase.GetSessionInfo(Int64& sessionID, String& serverName)
    at Scada.Client.ClientBase.RestoreConnection()
    at Scada.Client.ScadaClient.WriteChannelData(Int32 archiveMask, ICollection`1 slices, WriteDataFlags flags)
    at e.k()
    #12889
    Secret key of the client must match the secret key of the server. Copy the correct key from the Server settings.
