OPC Server Connection – E_NETWORK_ERROR
Forum Home › Forums › Communicating with Devices › OPC › OPC Server Connection – E_NETWORK_ERROR
Viewing 3 posts - 16 through 18 (of 18 total)
  • #6906
    You should read this post, and provide more info there.
    #7115
    heavenbird
    I have meet the “E_NETWORK_ERROR” porblem both in the windows Server2019 and windows Server2008 R2。
    I solved the problem in the following ways:
    1、run dcomcnfg
    2、if you can‘t find your opc server in 64bit system, try use “comexp.msc -32”
    3、Select the Identity tab. chang to “The interactive user”
    #7119
    Thank you for the solution.
