Forum Home › Forums › Communicating with Devices › Modbus › Modbus RTU comunication issue
- This topic has 15 replies, 5 voices, and was last updated 5 years, 8 months ago by
June 17, 2019 at 3:20 pm #5565
cooldjmc
ParticipantHi, i’m getting a comunication issue in Comunicator after some modbus rquests that are workink ok, i get this error messages:
2019-06-17 17:00:09 Communication session with the Device 4 “Compresor 4”, type: KpModbus, call number: 4
Request element group “Comp-DATA”
Send (8): 04 03 00 00 00 5D 84 66
Receive (5/5): 04 03 BA 00 00
Receive (186/186): 00 5C 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 28 00 24 00 1F 00 00 01 87 00 00 00 0C 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 12 00 02 00 08 00 28 00 2C 00 25 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 E2 01 4B 00 00 00 05 00 00 00 00 02 03 02 03 00 00 00 00 00 00 00 39 00 00 00 00 00 00 00 00 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 17 00 00 00 00 13 70
OK!2019-06-17 17:00:10 Communication session with the Device 4 “Compresor 4”, type: KpModbus, call number: 4
Receive (186/186): 00 5C 00 01 00 01 00 00 3F 3F 00 00 00 01 02 00 00 00 00 00 00 01 00 01 00 01 00 3F 3F 3F 3F 01 00 01 00 00 00 00 00 00 00 00 00 01 00 28 00 24 00 1F 00 00 01 87 00 00 00 0C 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 3F 00 00 00 00 00 00 01 02 04 08 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 15 00 12 00 02 00 08 00 28 00 2C 00 25 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 E2 01 4B 00 00 00 05 00 00 00 00 02 03 02 03 00 00 00 00 00 00 3F 3F 00 39 00 00 00 00 00 00 00 00 00 08 00 4B 00 00 00 00 00 00 00 00
CRC error!
Receive (0/5):
Communication error!
Receive (0/5):
Communication error!2019-06-17 17:00:14 Communication session with the Device 4 “Compresor 4”, type: KpModbus, call number: 4
Receive (0/5):
Receive (5/5): 04 3F 3F 03 BA
Incorrect PDU function code
Receive (0/5):
Communication error!2019-06-17 17:00:18 Communication session with the Device 4 “Compresor 4”, type: KpModbus, call number: 4
Receive (0/5):
Receive (0/5):
Receive (0/5):
Communication error!2019-06-17 17:00:23 Communication session with the Device 4 “Compresor 4”, type: KpModbus, call number: 4
2019-06-17 17:00:23 Error communicating with Device 4 “Compresor 4”: Error writing data: Uno de los dispositivos conectados al sistema no funciona.2019-06-17 17:00:23 Close serial port COM4
2019-06-17 17:00:23 Open serial port COM4
2019-06-17 17:00:23 Error executing the communication channel actions before session with a device: Error opening serial port: Access to the port ‘COM4’ is denied.2019-06-17 17:00:23 Unable to communicate with Device 4 “Compresor 4” because connection is not established
2019-06-17 17:00:24 Open serial port COM4
2019-06-17 17:00:24 Error executing the communication channel actions before session with a device: Attempt to open serial port can not be earlier than 5 seconds after the previous.2019-06-17 17:00:24 Unable to communicate with Device 4 “Compresor 4” because connection is not established
2019-06-17 17:00:24 Error executing the communication channel actions before session with a device: Attempt to open serial port can not be earlier than 5 seconds after the previous.June 17, 2019 at 4:54 pm #5567
How the devices are physically connected to Rapid SCADA server?
June 18, 2019 at 9:38 pm #5569cooldjmc
ParticipantHi, are conected with USB to Rs485 converters, there are 2, each one conected to a USB port on the mainboard. Each converter pulls 2 RTU Slaves. But the test i made is only with one slave active.
June 19, 2019 at 1:52 pm #5575
MikhailModeratorThe log says that there are problems with a converter:
2019-06-17 17:00:23 Error executing the communication channel actions before session with a device: Error opening serial port: Access to the port ‘COM4’ is denied.June 19, 2019 at 1:52 pm #5576
MikhailModeratorMay be other application uses the same port COM4.
June 19, 2019 at 9:27 pm #5582cooldjmc
ParticipantThank you for your answers. what i don’t understand is after this:
the COM port remains blocked and no other app can open it, also if i try restart the computer it won’t restart remains on “Shutting down windows ” screen and i must reset it.
June 20, 2019 at 3:19 pm #5585
MikhailModeratorSeems like hardware problem. What USB-COM converter do you use?
August 25, 2020 at 9:12 am #7197hethongscada62
ParticipantDear Mr. Mikhail.
I am creating a new project “Smart ScadaFarm” on Raspberry Pi4. It is running but not unstable. Maybe all my devices are connecting to RaspberryPi4-server via Rs485-WiFi converter. Is that the cause of instability?.
Now i want that all these devices will be connected to Raspberry Pi4 via RS485-USB converter. Can they connect to Pi4? How will i configure?
Thanks and best regardsAugust 25, 2020 at 2:56 pm #7199
You should provide communication logs to check.
Depends on the converter. I can’t suggest a particular. As I know, many of them work with RPi.
September 29, 2020 at 2:06 pm #7316kumajaya
ParticipantI recently have a bad experience with Moxa NPort device for transmit Modbus RTU over ethernet in RFC2217 mode. I have to compile Moxa Real COM driver for a stable communication. Working flawlessly after.
September 30, 2020 at 9:21 am #7325
MikhailModeratorUsing Moxa NPort, I prefer TCP server or TCP client mode.
December 31, 2020 at 3:18 pm #7905kumajaya
Participant@Mikhail Today I realized how simple NPort in TCP mode. Thank you.
Not actually NPort device I use here but a GSM modem from Moxa with a serial port. With a private IP from GSM operator, the only option to access it is via OnCell Central Manager. OCM map the serial port to a local TCP port.
January 2, 2021 at 9:54 am #7908
MikhailModeratorIf you use GSM modems, you can try a mode when Communicator is TCP server, and a modem is TCP client, so a modem doesn’t need static IP address.
January 3, 2021 at 6:30 am #7923kumajaya
ParticipantI’ll try it @Mikhail. For now I accessed it from Node-RED using node-red-contrib-modbus. I have to enable TCP in telnet mode because got incorrect Modbus stream in default TCP mode.
March 2, 2021 at 7:18 am #8369SGG
ParticipantHello Mikhail and team,
I have rapid scada connected to 6 modbus devices through rs485…they all worked and communicated effectively at first…2 days later, I observed that only the terminal (at the end of the daisy chain) device is communicating. When I turn off that device, it picks the next terminal device and communicates with it properly…I later changed the “number of request retries on error” in the communication parameter from the default 3 to 20 and all the device started communicating. I observed that for some devices, it takes about 14 retries before a response is sent by the device.I dont know what might be caussing this, although, I suspect I need to insert a terminating resistor of 120ohms…kindly help me with any suggestion from experience.
