Modbus Data Formula
Forum Home › Forums › Communicating with Devices › Modbus › Modbus Data Formula
Viewing 15 posts - 1 through 15 (of 20 total)
  • #13827
    TroyV23
    I am trying to read an alarm Register on a Modbus TCP device.
    I have it communicating correctly right now reading a float value.
    I want to read a Register at:
    HEX 0x812
    uint16 data type
    HiByte, Bit 0-2
    I know this must be a formula, I’m just not sure how to do it.
    #13828
    Please make a screenshot of the received data and provide an example what data you need to extract.
    #13874
    TroyV23
    • This reply was modified 2 years, 11 months ago by TroyV23.
    #13876
    TroyV23
    How Do I capture received data?
    #13878
    Check Communicator – Communication Lines – Your line – Line Stats – Line Log
    #13888
    TroyV23
    I just realized that my received data is missing the last 2 words?
    Sent:
    01 02 00 00 00 06 CE 04 08 0E 00 02
    Response:
    01 02 00 00 00 07 CE 04 04 00 00 FF FF
    I expected response to be:
    01 02 00 00 00 07 CE 04 04 00 00 FF FF 00 00
    Do you have any clues as to why that is?
    #13890
    Could you make a screenshot of the log?
    #13900
    TroyV23
    Screenshot
    #13901
    Communication works well.
    What tag data is displayed on the device data page? Could you clarify the question?
    #14223
    TroyV23
    I was able to get it working, my device actually had a modbus register that defined everything for me.
    I still have a question though:
    I have an alarm channel that either shows “0” when alarm is OFF or “256” when alarm in ON. When the event shows it gives a generic description that is not useful for users. Is there a way for me to define what the event says?
    I also want a formula to show “1” instead of “256” when alarm in ON.
    #14226
    The answer depends if you use Rapid SCADA 5 or 6. For version 6, set channel properties:
    Input formula would be Cnl > 0 ? 0 : 1
    Format is Off-On
    #14281
    TroyV23
    Format is Off-On
    Thanks!
    That worked perfectly, I just had to make a custom format to reverse the “Off-On” to “On-Off”.
    #14347
    TroyV23
    I now have the On-Off condition working but I realized it broke my LED scheme component condition. How do I make the LED indicator condition show green when no alarm, and red when alarm is on.
    The condition options have to be numbers, and that doesn’t work anymore.
    Thanks in advance!
    #14354
    Open the Conditions property of the component and change the colors.
    #14391
    TroyV23
    I reversed the conditions, it works now 🙂
