Modbus TCP Server
Forum Home › Forums › Communicating with Devices › Modbus › Modbus TCP Server
Viewing 4 posts - 16 through 19 (of 19 total)
  • #14522
    ibrahim eren
    Hello Mikhail,
    When I try using it as a TCP Client, it works. However, my field modems do not operate as TCP Servers, so it is essential for SCADA to function as a Server. It claims to be listening on the port, but when I check via a port checker, it is not actually listening.
    Thank you.log
    #14523
    ibrahim eren
      log
    • This reply was modified 2 years, 4 months ago by ibrahim eren.
    #14525
    ibrahim eren
    2024-05-22 14:27:14 Start communication line [1] Modbus
    2024-05-22 14:27:14 Connection listener on port 502 is started
    Load device template from file DrvModbus_NewTemplate.xml
    2024-05-22 14:27:14 Unable to communicate with the device [1] Modbus device because connection is not established
    2024-05-22 14:27:14 Unable to communicate with the device [3] JetRF2 because connection is not established
    2024-05-22 14:27:54 Connection listener is stopped
    2024-05-22 14:27:54 Communication line [1] Modbus is stopped
    2024-05-22 14:28:09 Start communication line [1] Modbus
    2024-05-22 14:28:09 Connection listener on port 502 is started
    2024-05-22 14:28:09 Unable to communicate with the device [1] Modbus device because connection is not established
    2024-05-22 14:28:09 Unable to communicate with the device [3] JetRF2 because connection is not established
    #14526
    According to the log, TCP server is waiting for incoming connections, but no client is trying to connect.
    Is Rapid SCADA installed on a cloud server or in the local network?
