Viewing 15 posts - 736 through 750 (of 6,265 total)
  • in reply to: Sending MQTT commands #15657
    Please provide screenshots of the settings, and commands sent.
    in reply to: Connection state is Error #15653
    May be some other application affected network communications. Windows update also may be the cause.
    I would prefer Linux for server software that needs to run 24/7.
    in reply to: Sending MQTT commands #15652
    You don’t need to add commands in the device properties. You can just write data to elements of subscriptions.
    in reply to: Sending MQTT commands #15651
    In the Administrator app, right-click the device, choose Send command. Type the tag code as a command code and send. Does it work? If not, check a communication line log.
    in reply to: DrvDbImportPlus #15647
    in reply to: Modbus Simulator Issues #15646
    Dear Bryan,
    Please copy in this topic a part of a communication line log that contains error details.
    in reply to: Sending custom data from SCADA Admin app to Server #15641
    If a path should be entered in the Administrator application, it can be done via module user interface. Like Auto Control Module does, for example. Module configuration is stored in an XML file as a part of the project.
    in reply to: ExtraSchemeComponentsPlugin Registration bug #15637
    I suppose, the plugin will generate the computer code when you upload the project, containing a scheme (mimic diagram) containing that components. And activate the plugin, of course.
    in reply to: JS file debug in MQTT integration #15635
    Use the log function as shown here.
    in reply to: install Plugin #15633
    I have my ‘own’ project, so not hello world from the installation process. Does this mean that the files have to be copied to a different location?
    ChartPro*.xml files should be copied in your project folder (where you saved it) as shown in the above post.
    • This reply was modified 1 year, 6 months ago by Mikhail.
    in reply to: Map Plugin not success #15631
    Copy PlgMap.xml from the distributive package to your project. Then upload the project again.
    in reply to: Hourly countdown formula #15615
    Thank you for the update.
    in reply to: Hourly countdown formula #15611
    Formulas of the calculated channels are called many times a second.
    Formulas of the input channels are called when data comes from Communicator. By default, Communicator sends all device data every minute. May be this is the cause.
    For what channel number do you use the function Timer48hactief?
    in reply to: Hourly countdown formula #15607
    Set status to 0 by the 2nd part of the formula. Docs
    in reply to: Conecction wirh DNP3 #15606
    How to connect a device that only supports DNP3?
    Could a Modbus-DNP3 gateway be an option? What else is there?
    Use a 3rd party OPC server or a hardware gateway.
