Viewing 15 posts - 661 through 675 (of 6,265 total)
  • in reply to: Telegram send request error #15957
    Do you still get the same error in Communicator?
    in reply to: Daily Data #15935
    Please clarify your question. Screenshots may help.
    in reply to: How to send a string in an input channel through MQTT #15934
    Currently, the MQTT client driver supports only numbers. You can convert incoming strings int numbers with JavaScript, and transmit numbers to Server as channel values.
    in reply to: Telegram send request error #15932
    Note. Don’t publish your bot token. It’s not safe.
    in reply to: Telegram send request error #15931
    Send request:
    https://api.telegram.org/botXXX/getUpdates?offset=0&timeout=5&allowed_updates=message
    Error executing request: The request was canceled due to the configured HttpClient.Timeout of 10 seconds elapsing.
    timeout=5 means that the Telegram server should send a response in 5 seconds. But it didn’t. May be they have some issues on their side, or there are internet provider issues.
    For testing, you could send the same request in a web browser.
    • This reply was modified 1 year, 4 months ago by Mikhail.
    in reply to: Formul #15921
    Separators depend on the culture that is set in the Administrator application.
    in reply to: There is a problem with Import Table #15919
    Could you provide screenshots that explain the question?
    in reply to: InitScripts() use #15918
    Probably channel data is not ready when InitScripts is called.
    What kind of channels do you need to initialize?
    in reply to: use PrevTime() #15917
    For a channel of the input type it depends on Communicator.
    The Communicator app sends data to Server after each session and every period (60 seconds by default).
    in reply to: InitScripts() use #15898
    If you use some variables in your scripts, you can initialize them in the InitScripts method, for example. It is called once when Server starts.
    in reply to: Script use #15889
    You can call the HourStarted function inside your own custom functions. It is auxiliary.
    in reply to: Script use #15888
    The CountPulse function should be used in a channel of the calculated type. It should refer another channel. If the 2nd channel changes from 0 to >0, the 1st channel is increased. Check the source code in the Scripts table.
    in reply to: Script use #15887
    EveryXXX function is executed many times a second. When a time is elapsed, the method passed as an argument is executed. Find the source code of the EveryPeriod function in the Scripts table.
    in reply to: Script use #15886
    Please ask questions in proper different topics.
    in reply to: After using Rapid Scada, individual ideas make suggestions #15885
    Thank you for your thoughts.
    Item 2. You can. Try Ctrl + C.
    Items 1 and 3 have been added to the back log.
