MikhailModeratorWhat actual result do you get in a table view?
I mean a screenshot of the web page.
Open Webstation – Application Options – Plugin Assignment and check that
Plugin for sending commands is PlgMain.
MikhailModeratorI have problem with change state of output in the same formula, I want send impuls to my modbus device.
The output value depends on the formula. In your formula 0 is returned. Also you should specify a device and Tag code for the channel.
MikhailModeratorOK, the settings are clear now. What actual result do you get in a table view?
January 14, 2025 at 9:29 am in reply to: why is Modbus RTU used for transmitting message formats in Modbus slave driver? #15985
Open the Custom Options page of the communication line settings, and add a new parameterTransModewith valueTCP
MikhailModeratorScreenshots are not available. Please fix them.
MikhailModeratorThe settings look correct.
Please check the ScadaWebConfig.xml file in the installation directory (not in the project). Were all settings transferred to the destination folder from the project?
MikhailModeratorAlso check your firewall. It may block the Communicator service.
January 10, 2025 at 9:50 am in reply to: Hello World Tutorial – “The requested view is not specified” #15967
Make sure that all required components have been installed.
MikhailModeratorMay be a table view is not so good to show daily data. It was designed mostly for hourly data.
Elastic Report can show daily data as HTML. You could try Elastic Report Plugin.
1. As a channel value
2. As a C# constant in the Scripts table.January 9, 2025 at 11:09 am in reply to: How to send a string in an input channel through MQTT #15960
MikhailModeratorIf you are a software develop, you can get the source code of the driver from GitHub and add the required feature.
We can do that by a contract, however it may be expensive.
MikhailModeratorThe screenshot is not available.
