MikhailModeratorCommands cannot be sent by a script. Commands can be sent by a module.
Try Automatic Control Module for sending commands.
Could you provide a full error message from the log for analysis?
MikhailModeratorPlease use this subforum if you write in Chinese.
MikhailModeratorAs far as I know, OPC UA supports certificates.
MikhailModeratorFirst of all, you need to receive data correctly. Could you provide screenshots of the settings and received data?
MikhailModeratorMikhail told me once that OPCUA input data goes directly to communicator devices (OPCDA servers in my example) without passing throuht RapidScada’s server Tags
It may depend on the configuration. If you transfer data using Communicator’s data source, it comes directly. If you use Auto Control Module, data can be converted by formulas.
MikhailModeratorThere are no screenshots at the link. This conversation seems useless. I’m about to close the topic.
January 17, 2025 at 11:00 am in reply to: I would like to inquire about the Service control command failed message. #16031
Please write questions in a proper topic. This topic is about service control command.
MikhailModerator
MikhailModeratorThe screenshot on Google Drive is not public.
MQTT driver can publish channel values, but not events.
Message description is built based on channel status and value. “Defined” is a channel status. If you rename a channel status in the Channel statuses table, event descriptions will change. -
