Viewing 15 posts - 5,596 through 5,610 (of 6,265 total)
  • in reply to: New Web App Idea? #1683
    Issue 1. You have to grant access to “folders” which are separate records in Interface table.
    If it doesn’t help, post screenshots of the tables, please.
    in reply to: Channel value addition #1680
    1. Add a new channel of the type Calculated Real.
    2. Enter a formula such as Val(1) + Val(2) and switch it on by the checkbox.
    3. Pass the configuration to Server and restart Server service.
    in reply to: New Web App Idea? #1678
    Also Chart Pro for the new web app is ready.
    And the new plugin Elastic Report, which allows to generate almost any form of report.
    If need them, please let me know (they are not published yet).
    in reply to: New Web App Idea? #1677
    It is done )) Download the beta again.
    Most likely, the official release will be in November 2016.
    in reply to: Showing Date and Time or Text in table and scheme #1676
    You can easily display a date on a scheme by putting the parts close to each other.
    But dates can be shown separately in a table view for now.
    It is planned to add date and time format to Rapid SCADA. I hope, in this year or till the next spring. If the issue is critical, you are welcome to sponsor this feature to get it fast 🙂
    in reply to: Display of current data value #1673
    The formula will be
    Cnl/1000; CorrectStat()
    in reply to: SCADA – communicator – unable to browse #1670
    Also you can add items to the configuration file manually and watch whether it works or not.
    File path: C:\SCADA\ScadaComm\Config\KpOpc_XXX.xml
    in reply to: SCADA – communicator – unable to browse #1669
    There are few similar questions:
    1st
    2nd
    3rd
    I think, you should try tuning DCOM configuration. How to open the config is described at the end of the article.
    in reply to: Display of current data value #1668
    Please, provide your value of the formula field of the input channel.
    in reply to: SCADA – communicator – unable to browse #1665
    Does this error appear for any folder of the OPC server?
    Could you try the same with Matrikon.OPC.Simulation server?
    in reply to: I need to read data format RTU modbus INT32-M10K #1664
    Does it work for the current time?
    in reply to: I need to read data format RTU modbus INT32-M10K #1660
    The approach is
    1. Receive data in UInt16 (4 Bytes)
    2. Create a formula in the configuration database (SCADA-Administrator, Formulas table) which decodes the data.
    3. Use the formula for your input channels in the Formula field.
    Do you have an algorithm how to convert INT32-M10K to normal integers or floats?
    in reply to: Display of current data value #1658
    1. Create a formula in the Formulas table:
    int CorrectStat()
      return CnlStat == 5 ? 0 : CnlStat;
    2. Add the expression in the Formula field of an input channel:
    Cnl; CorrectStat()
    Note: I didn’t test this answer. It should work, but may have mistakes.
    • This reply was modified 9 years, 7 months ago by Mikhail.
    in reply to: Display of current data value #1654
    Good idea, thank you.
    I’ve added it to the issue list.
    If it is critical to your project, it is possible to change the Unreliable status to Undefined by a formula of input channel.
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1651
    You can create special files. Try to stop SCADA-Server then send commands using Communicator. You can see the files in C:\SCADA\ScadaComm\Cmd
    There is an example how to do it.
