MikhailModerator1. Add Data Group by clicking “D” toolbar button.
2. Double click element in the left to add it to the group.
MikhailModeratorPlease provide screenshots what you’ve done and describe what you expect.
MikhailModeratorFS20:
To support this protocol in Rapid SCADA it is necessary to develop a special driver (it is a DLL) or find and use FS 20 OPC server if it exists.can Rapid SCADA read something from a text file and visualise it as a text variable?
Rapid SCADA able to display predefined text values.
For example,
0 – “Value Zero”
1 – “Value One”
etc.If you need to read data from a file, you also need to create a driver which recognize its format.
MikhailModeratorI’ve answered in another topic.
MikhailModeratorMove down to the end of the table and enter a new channel in the last empty row.
MikhailModerator1. Create a scheme using Scheme Editor. Save it to
C:\SCADA\Interface\MySystem\MyScheme.sch
or
Create a table view using Table Editor. And save it to
C:\SCADA\Interface\MySystem\MyTable.tbl2. Open Administrator. Open Interface table.
Add a new row
or
MySystem\MyTable.tbl3. Click Pass to SCADA-Server button and restart SCADA-Server service.
4. Relogin the web application.
MikhailModeratorPlease create a separate topic in Understanding the Software subforum.
MikhailModeratorIE is outdated.
Use Chrome, Firefox or Edge.when i upload my pictures,it often show that the web page can not be found,why?
I can’t reproduce this problem. You can try any other image hosting.
MikhailModeratorInstallation issues:
I suppose you did a few attempts to install. So ScadaServerService and ScadaCommService are already exist in the system.Web:
What browser do you use?
MikhailModerator1. Go to http://postimage.org
2. Upload your image
3. Copy the link in the forum.Also you can provide a link to a screenshot hosted on any public file hosting such as Google Drive or Dropbox.
MikhailModeratorit is the rapid scada 5.o,but it miss the sadaweb configuration,why?
See this answer.
when I uninstall the rapidscada 4.5,then I install the 5.0,it shows two faults.why?on they are scada commnication and service has been completed with the eror
Please provide screenshots or log text of the errors.
when i install the 5.0 and login in, i cannot look the views and table,why?
Please provide a screenshot.
Use postimage.org or similar hosting to post screenshots. Insert image links into your messages.
It’s better to provide links to the manuals.
MikhailModerator
MikhailModeratorWhich additional modules should I by and how can I display self made charts and displays.
This is the standard functionality which doesn’t require commercial modules.
I recommend Chart Pro Plugin for advanced charting. It is optional.
MikhailModerator2. Create a view using Table Editor or Scheme Editor. Save it into C:\SCADA\Interface
Then define a view in the configuration database in the Interface table using SCADA-Administrator. Use the default views as an example.In case of follow up question be free to ask.
