MikhailModeratorIt is possible by development a special module. It can by done by your side, or by my side as custom development. We can discuss it in details by email or by skype.
MikhailModeratorTo find a cause, debug and log needed. The source code is not enough.
There is a new possibility recently developed: you can install Rapid SCADA on your RPi and pass data from RPi to PC using Rapid SCADA internal protocol. This functionality is implemented by Rapid Gate module. You can download it by this link. In case of follow up questions, be free to ask.
Send me a letter to receive a trial key for Rapid Gate.
The communication log “says” that RPi drops the connection. Do you develop the Modbus server by yourself or use 3rd party software? Is there any logs of the Modbus server?
MikhailModeratorYou need to open port on Windows Firewall, allow incoming connection on the router and redirect data to your PC using NAT (on router).
There is no SCADA specific, just network administration.
MikhailModeratorRead this section. Pay attention to Timeout and Delay parameters of communication.
MikhailModeratorPlease describe how your sensors are physically connected?
First of all, you need to find out the bottle neck step by step. Please provide more details what are “locally displayed value” and “value on SCADA screen”? Screenshots will help.January 31, 2017 at 6:21 am in reply to: Raspberry Pi config: Metadata file `System.dll' could not be found #1914
MikhailModeratorAre you on Raspbian?
Yes.
You can try to install latest Mono manually as written here http://www.mono-project.com/docs/getting-started/install/linux/
I did it on Ubuntu just for testing.
MikhailModeratorCould you provide more details about the architecture of your system?
MikhailModeratorAlso you can install this utility and try to establish a connection between internal and external computers.
Does your web server located within home network or on a hosting in the Internet?
Seems you perform the right settings. What errors in log files of server and web application?January 28, 2017 at 3:25 pm in reply to: Chartpro request: Separate rows for discrete / binary inputs, etc #1906
MikhailModeratorThank you. Very interesting suggestion!
January 27, 2017 at 5:06 pm in reply to: Chartpro request: Separate rows for discrete / binary inputs, etc #1902
MikhailModeratorCould you provide a graphical example, please?
